I recently flashed build 28000M on my R8000 and everything seems to be working ok except for a couple of things:
1. None of my LAN ports are working. I was assuming that when I plugged my NAS into LAN 1 it would appear on the DHCP client list without any further settings but it does not. If there is something I should be doing I would really appreciate some help.
2. I only see 2 wireless interfaces when I was expecting 3. Also, I have some bogus dd-wrt wireless network being created. Any ideas?
i am new to this and wanted to use dd-wrt for the access restrictions specifically so please go easy if I am asking basic questions or making silly mistakes.
my advise is stop with this version of dd-wrt, i have tried this version on my R8000 and lost of problems
also not bale to make a guest network, users cab login in and very ubstable.
i now have the original firmware running, less options, but stable and everything works.
my understandung was that dd-wrt was a good solid product, but many flaws :(
That's a shame. The access restrictions in dd-wrt look like just what I need.
Can you please tell me how I go back to the original firmware?
the same as you loaded dd-wrt
again i dont understand people use dd-wrt
perhaps for old routers, but for the new....only lots of problems
no stable version at all
its to bad :-(
I wanted to use did-wrt because the parental controls on opendns are not good enough. I want to be able to set different time limits for different ip addresses. I will try to buy a new fritz box. I've got an old fritz box but it's starting to have a few issues. It's parental controls are excellent.
Reverting to the netgear firmware is not as easy as you suggest. I tried that and it didn't work. There is an article on here relating to a different router which uses the erase Linux command then using telnet to put the original firmware downloaded from the netgear site. That worked for me.
