I recently upgraded to the v3.0-r28000M kongac (10/24/15) build and since doing so I'm having issues with my NAS not automatically being seen after a router reboot. It's connected directly, and I had no problems with it with the last build (mid 2014). I haven't made any changes on the NAS side, so I'm lead to believe it's an issue with DD-WRT. I've tried different cables in different ports with no luck. I should note that I can't even ping the device, and the router doesn't see it as being connected either.
Any suggesstions? I'd hate to have to flash an older version.
For anyone running into similar problems, I was able to find an acceptable (but not ideal) solution. I disabled DHCP on my NAS and had it request the same static IP the router was assigning it, which seems to have resolved it, it's now seen immediately after a router reboot. Unfortunately this method won't work for a client that doesn't have an option to assign an IP internally.
Hello ,Are you talkig abouth the dd-wrt.K3_R620_0.chk FW ,from 10-26-15 ? the latest one in FW thread ? Could you tell mhat exactly doesn't work?
