Hi all,
I have finally received my R7000 yesterday and flashed it with Kong's latest built.
Afterwards I setup OpenVPN as per explanation on Privateinternetaccess.
Now I am facing the following problem while using the R7000 as an AP:
While the LAN connections work (using OpenVPN) my WiFi connections aren't using OpenVPN, which I find surprising as they are all supposed to run on the same bridge (default setting).
Anybody encountered same issue?
-Czywy
what's ur OpenVPN config look like?
Basically like this:
https://www.privateinternetaccess.com/pages/client-support/dd-wrt-openvpn
Issue solved (sort of): I went for Merlin's firmware. Working like a charm.
