OpenWRT Firmware for NETGEAR D7800 Now Available
For lucky D7800 owners, there is now an OpenWRT custom firmware available for download.
Head over to our downloads section to grab the alpha release, and make sure to post to our forums with what you think!
Category:
Hani_RS
Hani_RS's picture
Hopefully the D7000 will join
Hopefully the D7000 will join the club and witness a support for open-wrt in the days to come.
Really looking forward to this having recently brought this new modem
civlowwer
civlowwer's picture
NO DSL support???? I hope
NO DSL support???? I hope this will be available soon as i would love to use a custom firmware for my vpn
Iowa_Power
Iowa_Power's picture
Is there nowhere to get
Is there nowhere to get custom firmware for the D7000? This thing is clunky as hell and I keep hearing about how custom firmware can be a lifesaver, but I can’t find anything out there for this model... and OpenWRT doesn’t appear to be too concerned since they aren’t responding to requests for information here on this site..... Feed back would be great!
rxk
rxk's picture
Does this open firmware can
Does this open firmware can fix login page problem on my Win 8.1 PC. I tried using www.routerlogin.net, 192.168.0.1, 192.168.1.1 and even www.routerlogin.com still no success. I followed Netgear's help webpage and called their technical support but they still can't help me.
I checked ipconfig, the default gateway is 192.168.1.1 and successfully ping with no loss. I disable firewalls but still can't access login page.
I am not sure why my Win 8.1 & 10 machine can't access while my win 7 and my phone is working as expected.
I hope someone can help. Is this compatibility issue with win 8.1 and netgear D7800?
Aid
Aid's picture
Are you all sorted now Ray?
pzh_xg
pzh_xg's picture
It is long time for D7800
It is long time for D7800 from last openwrt firmware,and so many bugs,when it is can update firmware !
pzh_xg
pzh_xg's picture
<hr />
<hr />
Installing webui-aria2 (2016-10-11-1) to root...
Downloading http://downloads.openwrt.org/snapshots/trunk/ipq806x/generic/packages/pa....
Configuring aria2.
Configuring luci-app-aria2.
Configuring luci-app-qos.
Configuring webui-aria2.
//usr/lib/opkg/info/aria2.postinst: line 4: default_postinst: not found
//usr/lib/opkg/info/luci-app-aria2.postinst: line 4: default_postinst: not found
//usr/lib/opkg/info/luci-app-qos.postinst: line 4: default_postinst: not found
//usr/lib/opkg/info/webui-aria2.postinst: line 4: default_postinst: not found
Collected errors:
* pkg_run_script: package "aria2" postinst script returned status 127.
* opkg_configure: aria2.postinst returned 127.
* pkg_run_script: package "luci-app-aria2" postinst script returned status 127.
* opkg_configure: luci-app-aria2.postinst returned 127.
* pkg_run_script: package "luci-app-qos" postinst script returned status 127.
* opkg_configure: luci-app-qos.postinst returned 127.
* pkg_run_script: package "webui-aria2" postinst script returned status 127.
* opkg_configure: webui-aria2.postinst returned 127.
i don't konw,why is like this,install aria2,
the firmware is D7800-OpenWRT-Dec012015,and there is no new firmware for D7800
<hr />
&nbsp;
elemental.tm
elemental.tm's picture
Hi, would someone in the know
Would someone in the know kindly provide an update on this Project as it seems this Thread/Project has fizzled out. FYI I'm specifically trying to gather data around Custom Firmware for Netgear ROUTER+VDSL2 MODEM Combo's. AKA:
Thanks in advance, e.tm
