I am running a R7000 with DD-WRT v3.0-r28514 std (12/28/15).
I have setup 3 VAP, with 1 subnet each, with dedicated dhcp.
However, I am unable to have the authentication to work (WPA2/AES). I tried several different security scheme....
If I disable it, it works, as soon as I turn it on, my clients are unable to connect.
My Wireless interface are setup with "Network Configuration" in bridge mode.
Any clue ?
Thank you.
It works fine in my setup.
Try adjusting the channel, channel width and other setup in wireless basic setup page. Remove the saved ssid from your client machine.
I tried to cange the channel and other basic settings, same issue.
I also tried the latest release (DD-WRT v3.0-r29015M kongac (02/01/16)) without any success !
Is there a way to have some log/debug output of the authentication pahse ?
Thx
Configure wireless 2.4 GHz as follows,
Sorry one mistake,
Kill the 5g and try only on 2.4.
The new release seems to be locking up my R7000(some sort of bug), older one worked fine 10/24/15
i had same issue. i tried kong info page and followed with creating the bridge and it worked.
http://tips.desipro.de/
