Hi
Is there any information available on improvements made on the latest Kong firmware updates?
All I can see is a download for a firmware update nothing about what was improved, fixed or added as feature to the firmware.
Maybe I'm not looking hard enough.
I'm using a Netgear R7000 Nighthawk.
Thank you
i agree. where can we view the Changelog of each new firmware
Kongs latest firmware is available here ;
http://www.desipro.de/ddwrt/
but there doesnt seem to be a changelog section anywhere ? (there used to be though?)
On this same note, there is only a chk file for the R7000. I substituted "2015" with "2016" in the link in the readme.txt file then navigated to the most recent build (today) and there is a bin file. Does anyone know if this a working firmware beta?
ftp://ftp.dd-wrt.com/betas/2016/03-02-2016-r29193/netgear-r7000/
Above is the link in case you don't feel like going through the motions yourself :-)
Just FYI
I was having issues with the Kong firmware not allowing guest wifi to work and stumbled across
Tathagata firmwares and with the release you can see the updates made.
https://www.myopenrouter.com/download/dd-wrt-tathagata-netgear-r7000-nig...
Once the above firmware was applied to my R7000 guest wifi started working.
I think I'll stick with Tathagata firmware updates from now on.
