WLAN and VLAN
4 posts / 0 new
Rattlehead.ie
WLAN and VLAN
Hey guys,
Just hopefully looking for a yea/no answer and then try to figure it out.
I've a Juniper SRX with 3 VLANs. MGMT, LAN, Guest. I want to setup a single trunk port with all 3 VLANs connect to my R8000. Then broadcasting 2 different SSIDs assign Guests into Guest VLAN and normal users into the LAN VLAN all while still managing the R8000 via the MGMT VLAN....of course the MGMT VLAN I dont want on any SSID.
Is this something I can do with the Kong Firmware?
Drewrobinso
Not sure if entirely possible
Not sure if entirely possible, in DD-WRTs VLAN menu it only allows all wireless throughput to be allocated to one VLAN. You might be able to Frankenstein it and forward an unbridged Wi-Fi connection to other routers that would host the separate networks.
Rattlehead.ie
Thanks mate
Thanks mate
Had a look and some testing and still couldnt get it to work. So I think thats a non runner for now.
da_Beast
I am trying to do something
I am trying to do something similar - have to vlan tag on 1 of the wired ports to the device handling the routing.  I haven't had time to get into it but I was looking at the below article to start (assigning 1 SSID to a seperate bridge, that bridge having a seperate vlan, tagging out one of the wired ports to my firewall).
http://www.dd-wrt.com/wiki/index.php/Separate_LAN_and_WLAN
