I flashed my R8500 with Kong build "dd-wrt.K3_R8500.chk".
I am now unable to revert back to Stock firmware. I tried both from web user interface and CFE.
The stock firmware is getting flashed but continuously rebooting. The log before each reboot is stated below:
--------------------isDhdReady()------------------------
eth1: Cannot assign requested address
isDhdReady 4949 found eth1 ret=0x63
eth2: No such device
isDhdReady 4945 could not found eth2 ret=0x13
eth3: No such device
isDhdReady 4945 could not found eth3 ret=0x13
-------------------isDhdReady flag=2-----------------------------
DHD didn't bring up all the interfaces!
reboot: rmmod dhd failed: No such file or directory
Terminated
eth1: cmd=2: Invalid argument
shutdown_system:212:(eth1): cannot bringup, err = -1
eth1: WLC_SET_VAR(dngl_wd): Operation not supported
shutdown_system:216:(eth1): setting iovar "dngl_wd" to 0x1 failed, err = -1
Sending SIGTERM to all processes
Sending SIGKILL to all processes
Is there any user who got the same issue?
Any help?
Thanks in advance.
Sayan
Mine did the same thing when I went back, I performed a 30/30/30 reset, then let it attempt to boot completely, then did a regular 10 second reset, then it worked.
Here's a video explaining to 30/30/30 reset:
https://www.youtube.com/watch?v=gczCzP9Rry0
Curious to know why you reverted back to the stock firmware? I'm thinking about putting this on mine.... (for no good reason other then bordem).
I'm thinking about going back. My 5g signals dropped signficicantly and nothing I do is fixing it. My first 5g radio onyl has two wifi bars even right next to it while the 2nd has at least 4, but not maxed even right next to it. Besides adding openvpn I'm not seeing any advantages to keeping dd-wrt. But i've spent some much time trying to figure out my radio transmission al the positives began to fade.
