I'm currently using this build and I've noticed that connections seem slow to intialize but once they are established they are as expected. It seems to span various protocols/devices as I've noticed it with multiple devices and applications. Anyone else using this build or notice this on the R7000 with this build?
my connection speed is now at most half of last build. 2.4g went from 600M -> 240Mbps, 5G 400Mbps at most.
Looked at about of 20 min. worth of syslog entries. Nothing was erroring out. I'm not sure where to look to find where the issue lies. Could be pretty deep in the firmware's code. Like, an over-generous timeout or inefficent call.
I'm rollong back to previous firmware for now. Will try again when he releases a new one.
My version: DD-WRT v3.0-r29300M kongac (03/30/16)
I upgraded last night and so far so good. Are there release notes for these that you can point me to? I'm new to dd-wrt
I installed DD-WRT v3.0-r29300M kongac (03/30/16) on my two R6250 routers on April 3rd and everything is running smooth.
