Noob question re: login to router not asking for password
3 posts / 0 new
Guenth
Hello, I have a problem. My router is the Netgear R7000. I Flashed DD-WRT v3.0-r29300m. Everything went fine I think. but when I leave the control panel web page and try to log back in I'm just in the routers control panel. It doesn't ask me for a username and password that I made for it. If I click security, it then askes me for it but you can go anywhere else without it. How can I fix this?
Thank you
Guenth
NVM I figured it out...
vmsanta
I would like to know the
I would like to know the answer to this as well. I haven't figured it out
