I have been able to locate the R8500 .chk file but there is no .bin file that I can find. DD-WRT betas also do not have the .bin file in ftp://ftp.dd-wrt.com/betas/2016/04-11-2016-r29440/
They don't even have an entry for Netgear R8500.
Where is the .bin file to flash DD-WRT or is it only the .chk file that is needed?
Also, which version is better the Kong or the Tathagata version?
Here is the .BIN file
http://desipro.de/ddwrt/K3-AC-Arm/
Build dd-wrt.v24-K3_AC_ARM_R8500.bin supports:
Thanks for the location. Installed and up and running.
ist the chk file ore the bin file for the 8500 ?. please what must i install ?
thanks for help.
Kong pm'ed me a ways back and told me just to run the .chk file asthe bin file isnt needed.
