how to unbrick R7000 via telnet?
5 posts / 0 new
teleRN
teleRN's picture
Flashed from kong to tomato having forgot about needing to flash to original first. Now i cannot login to 192.168.1.1 with admin:admin
I read shibby's post:
In dd-wrt password is encrypted and this is why old password does not work after install tomato (or back from dd-wrt to Genie).
Do this:
1) run router and wait 2-3
5) use result as password
Maybe i am doing it wrong? I connect via telnet using the router's IP. I changed the port to "233. I turn on the router, hold the wifi on/off button (second from end), try to connect but cant. Connection fails. I can connect if i leave the port to 23 or 22, but it asks for RT login to which i am trying to figure out.
I have working lan, but no broadcasted wifi.
teleRN
teleRN's picture
I managed to log in. Turns
I managed to log in. Turns out you need to really hold the wifi button awhile. And after retrieving the username password i had to use firefox to log in instead of chrome as it would fail to log in maybe because of the length of it all? I copied it over, typed it to no avail until i switched browsers...
lesson learned.
on a second note i notice that shibby doesn't have ac support?? I cant see ac under 5ghz as a selectable option just N and A.
Accid
Accid's picture
Good information.
Good information.
Sleepy_Eyez
Sleepy_Eyez's picture
How are you guys connecting
How are you guys connecting R7000 to computer?
WAN or LAN or USB?
B42
B42's picture
Could I ask if you remember
Could I ask if you remember specifically what admin/password came up whn you did this.
I have same problem - but have tried to used this procedure multiple times. But cannot get this 'backdoor' to open. Som telnet does not connect
