NETGEAR R8000 Nighthawk (Rev 29627) 5GHZ WEP only?
5 posts / 0 new
incuzzz
Hey,
i just flashed to the current June Rev and nomatter which security Setting i chose on the two 5ghz Bands it only uses WEP :/
Tryed reflash, same issue.
Any ideas?
regards
magellat
Same issue here;soft reset
Same issue here;soft reset did fix it;however,cannot connect to 2.4 GHz...on Channel 1,6 or 11,no matter !
imran619
Same issues here i just
Same issues here i just posted on the other section not realising people are experiening the same issue
guess il be downgrading.
I was using Dec Firmware.
Anyone had issues with OpenVPN issues on DEC firmware?
imran619
Iv gone back to the old
Iv gone back to the old firmware
LordDarlymple
Dec Firmware - ExpressVPN
Dec Firmware - ExpressVPN OpenVPN configuration did not work for me.
With Jun firmware - ExpressVPN configuration did work - like a charm. However, speed is quite slow both on wired and wireless (much higher if directly installed on the laptop).
I finally got the Jun firmware working after doing 'erase nvram' and 'reboot' after the flash. All radios working fine. Earlier the 5 GHz radios were always off and I even if I renamed them, it sitll showed up as ddwrt on wifi networks.
