I'm having alot of problems with DD-WRT
v3.0-r29850M kongac, it was amazing to begin with, amazing wifi, wifi
was the best ive ever had it, set everything up. the wifi went off 24
hours later, and i could not get to the router by ethernet, turned it
off, back on, same thing happened again, with in 1 minite of the router
being turned on, rebooted it again, the router would not turn on WIFI
lights never turned on, no ethernet, rebooted it again, same thing,
rebooted it again and it turned on, its been fine for an hour now, just
in case i have turned logging on,
more info at : http://www.dd-wrt.com/forum/viewtopic.php?p=1035241#1035241
link above is wrong, please follow this link :
http://www.dd-wrt.com/phpBB2/viewtopic.php?t=302393&postdays=0&postorder=asc&start=0
Broken Build 29850M has been upgraded to Build 29580M
You can download it "Here"
if that link does not work, try "Here" then pick the Build for your router
* The new Build has no problems that I can find, Thanks to Build 29850M we now have better wifi, but with out the reboot bug
Release Notes can be found here :
http://www.dd-wrt.com/phpBB2/viewtopic.php?t=301499&postdays=0&postorder...
