DD-WRT Update Releases for R7000 and R8000 Nighthawk Routers
Devoted firmware crafter Tathagata Das has released two new builds for NETGEAR Nighthawk routers today. These are support releases of DD-WRT based on revision 29627.
Click here to download DD-WRT from Tathagata for the NETGEAR R7000.
Click here to download DD-WRT from Tathagata for the NETGEAR R8000.
rootintootinrouter
Lucky for us R8000 owners we
Lucky for us R8000 owners we have three new builds to choose from! I would like to upgrade from stock but which build to choose? Does anyone out there have an opinion?
Please way in if you have any experience with the last 3 R8000 builds. Kong, shibby and Tagathiba allave made generous contributions to the forum. How about showing some appreciation and providing some feedback.
rootintootinrouter
IdcWtfLol
I am curious aswell about
I am curious aswell about some feed back, I just purchased a R8000 and am not sure which build to use either
imran619
I'v upgraded from December
I'v upgraded from December build as OpenVPN don't work on the old build.
This build has buggy wifi and you can't add additional 5ghz ssid's as defaults to WEP so it's a big no no for me although OpenVPN works,
christianwis
hi folks, I need that this
hi folks, I need that this firmware have a gdrive client...it is possible ? Thanks in advance Christian
jibrilg
On R7000, this is build
On R7000, this is build constantly turn off my wifi radio on both 2.4ghz & 5ghz band. Please provide a solution ASAP
