After installing Tomato all i get is an amber power light. I tried to unbrick it but putty won't open the serial connection and I cant ping the router with a static IP set on my pc. any suggestions?
rough.
did you flash stock firmware before flashing tomato? or did you flash tomato straight from dd-wrt
How did you flash? Did you use the initial file first for the R8000?
Use usb to ttl and tftp to flash the router
Did you flash with the "initial" file first?
http://myopenrouter.com/download/tomato-firmware-shibby-netgear-r8000-in...
shibby also provided some video instructions which can be found on his site, or here:
http://tomato.groov.pl/download/K26ARM7/136-MultiWAN/
You may have to recover via TFTP:
http://myopenrouter.com/article/how-set-serial-console-netgear-r8000
