Hi dear,
I have encounter an error:
ap/gpl/iserver/libunistring-0.9.3/doc/uninorm.texi:198: unkowned command "arrow"
I can't solved this problem, but the doc directory seems to be documents, so I just delete "@" and "{}", luckily it complete without error.
When I got the image "R7000_****.chk"(29.1MB), I upgrade the system with the image.
After reboot, it currupt when loading the squash filesystem. It's serial only print to "lookup_nflash_rootfs_offset: offset = 0x200000" and no output further.
How to solve this problem? Any answer is satisfy.
BR
Hi, I am running into same problem. Did you get any solution to this problem?
