Forum DD-WRT Netgear R7800: http://www.dd-wrt.com/phpBB2/viewtopic.php?t=289788
- Hope this helps.... 2 weeks 9 hours ago
- I have been a diehard nether 2 weeks 6 days ago
- Have you fixed this problem? 4 weeks 19 hours ago
- Sending firmware via tftp did 1 month 1 week ago
- Did you find a way to do 1 month 2 weeks ago
3) hard reset
Can someone plz tell me step by step how to flash KONGs FW on my R7800. I am runing the latest Netgear 1.0.2.04 and having issue connecting to
ipv6. I have never done a fw flash on a router and a little worried that I might brick it. From What I undertstand, and maybe i m wrong, I ll have to flash 2 files????
1. R7800 factory to ddwrt.img
2. Once that is done, then I flash ddwrt R7800.bin
Is this right? Any help would be appreciated.
Best regards
factory-to-ddwrt - only first setup from stock to dd-wrt firmware.
ddwrt.bin - upgrade dd-wrt version from old dd-wrt to new dd-wrt firmware.
Thank you for your easy to understand ddwrt instruction . I was stuck and confused but your post just got me into the right direction and now its working fine.
can you set reservations with this? i cant see anyway how too
Is there anyway to get this speed with dd-wrt or openwrt http://www.speedtest.net/my-result/6829059018
I can't seem to get anything higher than 600Mbps unless i use stock or voxel's firmware.
What are your speeds LAN wired when speed testing. It's not recommended to test wireless as wireless has many variables that can cause inaccurate results.
Test with any QoS disabled first.
