Installed OpenWrt 12.09.1 firmware, did factory reset, but WiFi available only bg and a.
- Working the EXACT same 11 months 4 days ago
Latest build OpenWRT: https://downloads.openwrt.org/snapshots/trunk/ipq806x/generic/
LEDE project: https://downloads.lede-project.org/snapshots/targets/ipq806x/generic/
lobyte, USB ports do not operate currently in lede, I failed to add support for it. Any help would be appreciated.
Unfortunately USB ports do not work on latest firmware OpenWRT and LEDE.
Enable USB ports:
echo -n 15 > /sys/class/gpio/export
echo -n out > /sys/class/gpio/gpio15/direction
echo -n 1 > /sys/class/gpio/gpio15/value
echo -n 16 > /sys/class/gpio/export
echo -n out > /sys/class/gpio/gpio16/direction
echo -n 1 > /sys/class/gpio/gpio16/value
The latest build LEDE OpenWRT 22.08.2016 r1399 include support USB for R7800.
thank you
The latest build LEDE can't install block-mount
No new firmware yet?... wanna try it but it but the version is very old...
The date of the newset firmware is October 3rd. Seems new to me.
First stable release build LEDE Project: http://downloads.lede-project.org/releases/17.01.0-rc1/targets/ipq806x/g...
