Wndr4500v2
4 posts / 0 new
Lkn
Wndr4500v2
Goodbye to all
I'm new and I hope you can help me.
I've a fttc connection 100/10.
Until now I couldn't test the wifi speed, cause devices hardware limit.
I've bought a Samsung s7 and I made speed test.
All my devices support 802.11n in 2.4ghz and 5ghz both.
My smartphone can't reach wired speed. I tried with another s7 and the problem is the same.
I use an extender (willy 0.2) that used by pc reaches the wired speed.
The same extender with xbox360 reaches 1/3 broadband connection.
The ports on router are correctly opened for the console.
Finally with wifi network analyzer app I found link speed at 54mbps, so my router limit the speed in 802.11a.
I set 2.4ghz and 5ghz networks to 450 mbit, removed 20/40mhz consistency but it's always limited.
I tested with only smartphone connected by wifi, but no luck.
Can I force router use use 802.11n on 2.4ghz and 5ghz or I'm doing anything wrong?
Sorry for my English.
Thanks in advance for any help.
Lkn
Lkn
Up!
Up!
Lkn
I've found a solution.... WMM
I've found a solution.... WMM should be enabled and WPA2 passwords (for who uses the old unsecured WEP and WPA)
jaimedpcaus
Is that the N900 router?
