Back to Stock OEM Firmware NETGEAR R6300 v1
5 posts / 0 new
Julianocwb
Julianocwb's picture
Hi
I Have one NETGEAR R6300v1 with TomatoShibby 132, and would like of
return to stock (OEM) firmware, Can I do this direct of webgui of tomato
Shibby 132 ?
Thanks a lot
Best Regards
JulianoCWB
m4p
m4p's picture
I have an R6300 v1 and have
I have an R6300 v1 and have always had the stock firmware, so not sure on your answer.  But I had thought about putting Tomato on mine at one time, and I'm curious why you want to go back to stock.  Were you having problems with the Tomato firmware?
rdbrock78
rdbrock78's picture
Here is the latest stock
Kempster20
Kempster20's picture
I put the oem factory
I put the oem factory firmware back on r6300v1 and now cant log in.  admin and password dont work to get into router.  Any ideas?
microchip
microchip's picture
do a full factory reset with
do a full factory reset with the button then try again
