Static dhcp entry keeps blank
4 posts / 0 new
vmb
vmb's picture
hi,
Recently flashed my Netgear 7800 with software DD-WRT v3.0-r29695M std (05/16/16)
I tried to enter static dhcp clients, but my 7800 leaves the fields blank, even when I saved the data I entered the fiels are blank!  Can anybody help me by solving this problem?
thx!
vmb
vmb's picture
Update: flashed to this
Update: flashed to this firmware: DD-WRT v3.0-r30700M kongat (09/27/16).
Got the same result: fields keep blank after filing in mac-adres/ip.
vmb
vmb's picture
Problem solved: Apply setting
Problem solved: Apply setting after every rule... :-)
Zeljko1234
Zeljko1234's picture
You had a nice conversation
You had a nice conversation with yourself. Thx for making me laugh :)
