Hey Everyone,
I just got my R8000, booted it up, loaded on tomato (init -> AIO), spent some time setting up the following:
- Static IP
- Static DHCP
- dnsmasq
- vlan / guest wifi network
Everything seemed to be working fine (though the last thing I added was the vlan, I might not have rebooted right after I added that). I unplugged it from my computer and added it to my network as the primary router.
It immediately entered into a bootloop. I tried all the tools I had available to me, from holding down the reset button to yelling at it, to sulking, disconnecting it from the network and plugging it directly into my laptop again. Nothing seemed to work (although yelling made me feel better temporarily).
I went online and saw that some people had bootloops issues with the R7000 if they put it into client-bridge mode. I was pretty sure I didn't do that, but it was bootlooping, so I looked up the fix for that. Bought a usb/ttl cable and waited. Today my cable came and after carefully taking this monster apart (including that pesky hidden screw) I managed to connect up the 3 pins (ground, tx, and rx) to the board. I had tx and rx wrong though, so then I had to swap them. Finally, after much googling I was getting input on my screen showing my router failing in real time!
I spammed crtl-c, interrupted the bootup, a prompt! I checked the wlans to see if any of them were in client bridge... none, apparently that would be too easy.
I then figured, what the hell, let's just reflash it back to stock. And that's what I did. That first bootup was a wild ride, all kinds of new info on the screen, skipping merrily along where I believe it had failed previously. Then... it rebooted, and rebooted, and rebooted... bootloop still.
I googled, I reflashed, I googled, I reflashed. I am out of ideas. I'm not sure what I did to brick it, and I'm not sure what I can do to unbrick it. Any ideas you all have would be much appriciated.
Below is the log of my boot sequence. If you need anything else just ask.
Digital core power voltage set to 1.0VDecompressing...doneDigital core power voltage set to 1.0VSHMOO VER 1.13PKID07DC06011801080000000000001A103F01000000S300001EB000014B0RDLYW0 00000004RDENW0 00000037RDQSW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 -------++++++++++++++++++++++++++X++++++++++++++++++++++++++----02 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------03 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------04 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++--08 -------+++++++++++++++++++++++X++++++++++++++++++++++-----------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 ---------+++++++++++++++++++++++X+++++++++++++++++++++++--------11 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--12 ------+++++++++++++++++++++++++X++++++++++++++++++++++++--------13 --------------+++++++++++++++++++++++X++++++++++++++++++++++----14 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------15 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--P\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------01 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----02 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------03 -+++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------04 +++++++++++++++++++++++++++X++++++++++++++++++++++++++----------05 --+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------07 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--08 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------09 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++10 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------11 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--12 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------13 ----++++++++++++++++++++++++++++X+++++++++++++++++++++++++++----14 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------15 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--N\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 -------++++++++++++++++++++++++++X++++++++++++++++++++++++++----02 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------03 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 --------++++++++++++++++++++++++++++X++++++++++++++++++++++++++-08 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------11 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-12 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------13 ---------------++++++++++++++++++++++++X++++++++++++++++++++++--14 -----------++++++++++++++++++++++++X++++++++++++++++++++++++----15 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++WRDQW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-01 ++++++++++++++++++++++++++X+++++++++++++++++++++++++---------++-02 +++++++++++++++++++++++++X++++++++++++++++++++++++--------+++++-03 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-04 +++++++++++++++++++++++X++++++++++++++++++++++-----------++++++-05 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-----++++++-06 +++++++++++++++++++++++X+++++++++++++++++++++++----------++++++-07 +++++++++++++++++++++++++X+++++++++++++++++++++++++---------+++-08 +++++++++++++++++++++++X+++++++++++++++++++++++-+--------++++++-09 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------10 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-11 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------12 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------+++++-13 --++++++++++++++++++++++++X++++++++++++++++++++++++-------------14 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-15 ---+++++++++++++++++++++++++X++++++++++++++++++++++++-----------WRDMW0 00000024WRDMW0 00000026ADDR0000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ++++++++++++++++++++S++++++++++X++++++++++++++++++++++++++++++++Decompressing...doneCFE for Foxconn Router R8000 version: v1.0.8Build Date: Fri May 30 15:03:06 CST 2014Init ArenaInit Devs.Boot up from NAND flash...Bootcode Boot partition size = 524288(0x80000)DDR Clock: 800 MHzInfo: DDR frequency set from clkfreq=1000,*800*et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)CPU type 0x0: 1000MHzTot mem: 262144 KBytesDevice eth0: hwaddr 10-DA-43-87-39-76, ipaddr 192.168.1.1, mask 255.255.255.0gateway not set, nameserver not setChecking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)Loading: .... 4218016 bytes readEntry at 0x00008000Closing network.Starting program at 0x00008000console [ttyS0] enabled, bootconsole disabledserial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550brd: module loadedloop: module loadedpflash: found no supported devicesbcmsflash: found no supported devicesBoot partition size = 524288(0x80000)lookup_nflash_rootfs_offset: offset = 0x200000nflash: squash filesystem with lzma found at block 29Creating 5 MTD partitions on "nflash":0x000000000000-0x000000080000 : "boot"0x000000080000-0x000000200000 : "nvram"0x000000200000-0x000004200000 : "linux"0x0000003ad160-0x000004000000 : "rootfs"0x000002200000-0x000002240000 : "board_data"PPP generic driver version 2.4.2PPP MPPE Compression module registeredNET: Registered protocol family 24PPTP driver version 0.8.5=== PPTP init ===u32 classifierActions configuredNetfilter messages via NETLINK v0.30.nf_conntrack version 0.5.0 (3990 buckets, 15960 max)ctnetlink v0.93: registering with nfnetlink.xt_time: kernel timezone is -0000ip_tables: (C) 2000-2006 Netfilter Core TeamTCP cubic registeredNET: Registered protocol family 10ip6_tables: (C) 2000-2006 Netfilter Core TeamNET: Registered protocol family 17L2TP core driver, V2.0PPPoL2TP kernel driver, V2.0802.1Q VLAN Support v1.8 Ben Greear <[email protected]>All bugs added by David S. Miller <[email protected]>Registering the dns_resolver key typeNorthstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)Spare area=64 eccbytes 56, ecc bytes located at:2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63Available 7 bytes at (off,len):(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)Scanning device for bad blocksOptions: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,Creating 1 MTD partitions on "brcmnand":0x000004000000-0x000008000000 : "brcmnand"VFS: Mounted root (squashfs filesystem) readonly on device 31:3.devtmpfs: mountedFreeing init memory: 216KHit ENTER for console...emf: module license 'Proprietary' taints kernel.Disabling lock debugging due to kernel taintet_module_init: passivemode set to 0x0et_module_init: txworkq set to 0x0et_module_init: et_txq_thresh set to 0x400et_module_init: et_rxlazy_timeout set to 0x3e8et_module_init: et_rxlazy_framecnt set to 0x20fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.40 (r527781)fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.40 (r527781)eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.40 (r527781)dhd_module_init indhd_queue_budget = 256dhd_sta_threshold = 2048no wifi platform data, skipPCI_PROBE: bus 1, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0001:01:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach: ctf_attach() faileddhd_attach(): thread:dhd_watchdog_thread:2f2 starteddhd_deferred_work_init: work queue initializedDongle Host Driver, version 1.194.33 (r526004)Compiled in drivers/net/wireless/bcmdhd on Jun 17 2015 at 11:27:36Register interface [eth1] MAC: 00:90:4c:11:22:33dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-chkd2hdma-proptxstatus, 2015.06.17.111523, 2015/06/17 11:15:23).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.dhdpcie_readshared: address (0xfe0d01f2) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhd_bus_init :Shared area read faileddhd_bus_start, dhd_bus_init failed -1dhdpcie_readshared: address (0xfe0d01f2) of pciedev_shared invalidWaited 5006383 usec, dongle is not readyEnforcing kernel panicUnable to handle kernel NULL pointer dereference at virtual address 00000000pgd = cf914000[00000000] *pgd=8f164031, *pte=00000000, *ppte=00000000Internal error: Oops: 817 [#1] PREEMPT SMPlast sysfs file: /sys/kernel/uevent_seqnummodule: dhd bf024000 799274module: et bf011000 48925module: igs bf009000 11927module: emf bf000000 15169Modules linked in: dhd(+) et(P) igs(P) emf(P)CPU: 1 Tainted: P (2.6.36.4brcmarm #5)PC is at dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd]LR is at dhdpcie_bus_process_mailbox_intr+0x17c/0x1e8 [dhd]pc : [<bf037440>] lr : [<bf037460>] psr: 20000013sp : cf079cf8 ip : c0435ee4 fp : 00000000r10: c003c1d4 r9 : c043bf20 r8 : c0440cd8r7 : bf052d00 r6 : 00000000 r5 : 00000100 r4 : cf809000r3 : 00000000 r2 : cf078000 r1 : 60000013 r0 : 00000019Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment userControl: 10c53c7d Table: 8f91404a DAC: 00000015Process insmod (pid: 752, stack limit = 0xcf078270)Stack: (0xcf079cf8 to 0xcf07a000)9ce0: 00000000 cf8090009d00: 00000000 b83ef180 cf078000 cf809000 00000100 00000000 cf078000 bf047d089d20: 00000100 3b9aca00 cf29c000 cf29f898 00000000 bf02924c cf29f894 c006955c9d40: c0069450 0000000b c03ec058 cf078000 00000101 c003c148 c03ec040 c043bf209d60: 00000001 c03ade10 00000033 cf29c008 00000006 0000000a cf29c008 600000139d80: cf29c000 bf052d00 cf29c008 00000000 00000033 ffffffff 00000000 c0069a389da0: cf078000 c0069c44 cf29c008 bf02c890 00001788 cf0ac204 cf9e4000 cf9e40009dc0: cf0ac1e0 cf006cc0 cf809000 bf061000 000007f8 bf048f80 0000aa52 c017ccd49de0: cf9e4000 cf9e4000 00000000 bf056ee8 bf048d6c c017cea4 c017ce48 c0443c689e00: bf056f18 cf9e4060 bf056f18 c019a124 cf9e4060 bf056f18 cf9e4094 000000009e20: bf061000 c019a2ac bf056f18 cf079e38 c019a220 c0199380 cf8cc280 cf9ba7589e40: cf8cc250 bf056f18 c03fd1c8 cf0ac180 00000000 c0199a78 bf0506e4 c01651409e60: cf8cc240 bf056f18 bf056f18 c03fd1c8 00000000 bf061000 000007f8 c019a4b09e80: bf056ee8 bf056f18 c03fd1c8 00000000 bf061000 c017d10c 00000001 000000009ea0: c040e000 cf078000 00000000 bf038a54 00000001 00000000 c040e000 bf0610f89ec0: bf057010 c003e5bc 000007f8 c039de48 000000cb cf007ba0 00000000 bf0570109ee0: bf056fc8 bf057010 bf056fc8 cf214770 cf214400 00000000 000007f8 c00918a09f00: bf056fd4 4017b6a8 c00902c4 bf0570fc c043beec cf078000 d0c24578 000640089f20: cf004788 d0b71000 000ca494 d0c288ac d0c28677 d0c2cb84 cf039000 00034af89f40: 00037478 00000000 00000000 00000031 00000032 00000028 0000002c 000000199f60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c03bb6089f80: 00000003 0006c9f8 4020e008 00064008 00000080 c003ec68 cf078000 000000009fa0: 00000000 c003eac0 0006c9f8 4020e008 4020e008 000ca494 00064008 000000009fc0: 0006c9f8 4020e008 00064008 00000080 00000000 00000000 00060e7c 000000009fe0: 401199a0 be858c04 000123b4 401199b0 20000010 4020e008 00000000 00000000[<bf037440>] (PC is at dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd])[<bf037440>] (dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd]) from [<bf047d08>] (dhd_bus_dpc+0xc8/0x150 [dhd])unwind: Index not found bf047d08Code: e5973000 e3130001 1a000006 e3a03000 (e5833000)---[ end trace 58ecc25d2de7d3eb ]---Kernel panic - not syncing: Fatal exception in interrupt[<c0044ff8>] (unwind_backtrace+0x0/0xf8) from [<c02ed358>] (panic+0x7c/0x1a8)[<c02ed358>] (panic+0x7c/0x1a8) from [<c00426f8>] (die+0x1ac/0x1dc)[<c00426f8>] (die+0x1ac/0x1dc) from [<c0046390>] (__do_kernel_fault+0x6c/0x8c)[<c0046390>] (__do_kernel_fault+0x6c/0x8c) from [<c0046500>] (do_page_fault+0x150/0x1ec)[<c0046500>] (do_page_fault+0x150/0x1ec) from [<c003e3a4>] (do_DataAbort+0x30/0x9c)[<c003e3a4>] (do_DataAbort+0x30/0x9c) from [<c03ad46c>] (__dabt_svc+0x4c/0x60)Exception stack(0xcf079cb0 to 0xcf079cf8)9ca0: 00000019 60000013 cf078000 000000009cc0: cf809000 00000100 00000000 bf052d00 c0440cd8 c043bf20 c003c1d4 000000009ce0: c0435ee4 cf079cf8 bf037460 bf037440 20000013 ffffffff[<c03ad46c>] (__dabt_svc+0x4c/0x60) from [<bf037440>] (dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd])[<bf037440>] (dhdpcie_bus_process_mailbox_intr+0x15c/0x1e8 [dhd]) from [<bf047d08>] (dhd_bus_dpc+0xc8/0x150 [dhd])unwind: Index not found bf047d08CPU0: stoppingRebooting in 3 seconds..[<c0044ff8>] (unwind_backtrace+0x0/0xf8) from [<c003e334>] (do_IPI+0x114/0x154)[<c003e334>] (do_IPI+0x114/0x154) from [<c03ad4c8>] (__irq_svc+0x48/0xe8)Exception stack(0xc03ebf78 to 0xc03ebfc0)bf60: 00000002 cf9f7600bf80: c03ebfc0 00000000 c03ea000 c040e0a8 c03f6b80 c03f6b78 80000000 413fc090bfa0: 0000001f 00000000 00000000 c03ebfc0 c003fbe4 c003fbe8 60000013 ffffffff[<c03ad4c8>] (__irq_svc+0x48/0xe8) from [<c003fbe8>] (default_idle+0x24/0x28)[<c003fbe8>] (default_idle+0x24/0x28) from [<c003fd88>] (cpu_idle+0x70/0xa4)[<c003fd88>] (cpu_idle+0x70/0xa4) from [<c0008e8c>] (start_kernel+0x3cc/0x42c)[<c0008e8c>] (start_kernel+0x3cc/0x42c) from [<80008148>] (0x80008148)Digital core power voltage set to 1.0VDecompressing...doneDigital core power voltage set to 1.0VDecompressing...doneDigital core power voltage set to 1.0VSHMOO VER 1.13PKID07DC06011801080000000000001A103F01000000S300001EF000014E0RDLYW0 00000004RDENW0 00000037RDQSW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----02 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------03 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------07 --------++++++++++++++++++++++++++++X+++++++++++++++++++++++++--08 -------+++++++++++++++++++++++X++++++++++++++++++++++-----------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------11 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--12 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------13 ---------------++++++++++++++++++++++X++++++++++++++++++++++----14 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------15 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--P\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------01 --+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----02 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------03 -+++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------04 +++++++++++++++++++++++++++X++++++++++++++++++++++++++----------05 -+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------07 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--08 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------09 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++10 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------11 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--12 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------13 ----++++++++++++++++++++++++++++X+++++++++++++++++++++++++++----14 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------15 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--N\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 ------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++---02 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------03 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------07 ---------+++++++++++++++++++++++++++X++++++++++++++++++++++++++-08 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------11 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-12 -------+++++++++++++++++++++++++X++++++++++++++++++++++++-------13 ---------------++++++++++++++++++++++++X+++++++++++++++++++++++-14 ----------+++++++++++++++++++++++++X++++++++++++++++++++++++----15 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++++WRDQW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-01 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-02 ++++++++++++++++++++++++X++++++++++++++++++++++++-+-------+++++-03 +++++++++++++++++++++++++X++++++++++++++++++++++++--------+++++-04 +++++++++++++++++++++++X++++++++++++++++++++++-----------++++++-05 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-----++++++-06 +++++++++++++++++++++++X+++++++++++++++++++++++----------++++++-07 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-08 ++++++++++++++++++++++++X++++++++++++++++++++++++---------+++++-09 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------10 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-11 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------12 +++++++++++++++++++++++++X++++++++++++++++++++++++--------+++++-13 --++++++++++++++++++++++++X++++++++++++++++++++++++-------------14 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-15 ---+++++++++++++++++++++++++X++++++++++++++++++++++++-----------WRDMW0 00000024WRDMW0 00000026ADDR0000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ++++++++++++++++++++S++++++++++X++++++++++++++++++++++++++++++++Decompressing...doneCFE for Foxconn Router R8000 version: v1.0.8Build Date: Fri May 30 15:03:06 CST 2014Init ArenaInit Devs.Boot up from NAND flash...Bootcode Boot partition size = 524288(0x80000)DDR Clock: 800 MHzInfo: DDR frequency set from clkfreq=1000,*800*et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)CPU type 0x0: 1000MHzTot mem: 262144 KBytesDevice eth0: hwaddr 10-DA-43-87-39-76, ipaddr 192.168.1.1, mask 255.255.255.0gateway not set, nameserver not setStartup canceledCFE> ^CCFE> tftpdStart TFTP serverReading :: Done. 31223866 bytes readProgramming...done. 31223866 bytes writtenSkip writing CHK checksum for nflash.Digital core power voltage set to 1.0VDecompressing...doneDigital core power voltage set to 1.0VSHMOO VER 1.13PKID07DC06011801080000000000001A103F01000000S300001E7000014C0RDLYW0 00000004RDENW0 00000037RDQSW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----02 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------03 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 ---------+++++++++++++++++++++++++++X++++++++++++++++++++++++++-08 -------+++++++++++++++++++++++X++++++++++++++++++++++-----------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------11 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--12 ------+++++++++++++++++++++++++X++++++++++++++++++++++++--------13 --------------+++++++++++++++++++++++X++++++++++++++++++++++----14 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------15 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--P\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------01 -+-++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----02 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------03 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------04 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------05 -+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------07 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--08 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------09 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++10 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------11 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--12 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------13 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----14 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------15 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--N\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ---++++++++++++++++++++++++++X+++++++++++++++++++++++++---------01 ------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++---02 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------03 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 --------++++++++++++++++++++++++++++X++++++++++++++++++++++++++-08 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------09 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++10 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------11 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-12 ------+++++++++++++++++++++++++X++++++++++++++++++++++++--------13 ----------------++++++++++++++++++++++++X+++++++++++++++++++++--14 ----------+++++++++++++++++++++++++X++++++++++++++++++++++++----15 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++++WRDQW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-01 ++++++++++++++++++++++++++X++++++++++++++++++++++++++--------++-02 +++++++++++++++++++++++++X++++++++++++++++++++++++--------+++++-03 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-04 +++++++++++++++++++++++X++++++++++++++++++++++-----------++++++-05 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-06 +++++++++++++++++++++++X+++++++++++++++++++++++----------++++++-07 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-08 ++++++++++++++++++++++++X++++++++++++++++++++++++--------++++++-09 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------10 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-11 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------12 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-13 --+++++++++++++++++++++++++X+++++++++++++++++++++++++-----------14 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-15 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------WRDMW0 00000024WRDMW0 00000026ADDR0000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ++++++++++++++++++++S++++++++++X++++++++++++++++++++++++++++++++Decompressing...doneCFE for Foxconn Router R8000 version: v1.0.8Build Date: Fri May 30 15:03:06 CST 2014Init ArenaInit Devs.Boot up from NAND flash...Bootcode Boot partition size = 524288(0x80000)DDR Clock: 800 MHzInfo: DDR frequency set from clkfreq=1000,*800*et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)CPU type 0x0: 1000MHzTot mem: 262144 KBytesDevice eth0: hwaddr 10-DA-43-87-39-76, ipaddr 192.168.1.1, mask 255.255.255.0gateway not set, nameserver not setChecking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)Loading: ..... 4982560 bytes readEntry at 0x00008000Closing network.Starting program at 0x00008000console [ttyS0] enabled, bootconsole disabledserial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550brd: module loadedloop: module loadedpflash: found no supported devicesbcmsflash: found no supported devicesBoot partition size = 524288(0x80000)lookup_nflash_rootfs_offset: offset = 0x200000nflash: squash filesystem with lzma found at block 31Creating 17 MTD partitions on "nflash":0x000000000000-0x000000080000 : "boot"0x000000080000-0x000000200000 : "nvram"0x000000200000-0x000002600000 : "linux"0x0000003eef20-0x000002600000 : "rootfs"0x000002600000-0x000002680000 : "board_data"0x000002680000-0x000002780000 : "POT1"0x000002780000-0x000002880000 : "POT2"0x000002880000-0x000002b40000 : "T_Meter1"0x000002b40000-0x000002e00000 : "T_Meter2"0x000002e00000-0x000002e80000 : "ML1"0x000002e80000-0x000002f00000 : "ML2"0x000002f00000-0x000002f80000 : "ML3"0x000002f80000-0x000003000000 : "ML4"0x000003000000-0x000003080000 : "ML5"0x000003080000-0x000003100000 : "ML6"0x000003100000-0x000003180000 : "ML7"0x000003180000-0x000003200000 : "QoSRule"PPP generic driver version 2.4.2NET: Registered protocol family 24PPPoL2TP kernel driver, V0.17tun: Universal TUN/TAP device driver, 1.6tun: (C) 1999-2004 Max Krasnyansky <[email protected]>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driverehci_hcd 0000:00:0b.1: EHCI Host Controllerehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00hub 1-0:1.0: USB hub foundhub 1-0:1.0: 2 ports detectedohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driverohci_hcd 0000:00:0b.0: OHCI Host Controllerohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000hub 2-0:1.0: USB hub foundhub 2-0:1.0: 2 ports detectedxhci_hcd 0000:00:0c.0: xHCI Host Controllerxhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000xhci_hcd 0000:00:0c.0: Failed to enable MSI-Xxhci_hcd 0000:00:0c.0: failed to allocate MSI entryusb usb3: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum valuesxHCI xhci_add_endpoint called for root hubxHCI xhci_check_bandwidth called for root hubhub 3-0:1.0: USB hub foundhub 3-0:1.0: 1 port detectedcsw_retry 100Initializing USB Mass Storage driver...usbcore: registered new interface driver usb-storageUSB Mass Storage support registered.u32 classifierActions configurednf_conntrack version 0.5.0 (3979 buckets, 15916 max)ip_tables: (C) 2000-2006 Netfilter Core TeamTCP cubic registeredNET: Registered protocol family 10lo: Disabled Privacy ExtensionsIPv6 over IPv4 tunneling driversit0: Disabled Privacy Extensionsip6tnl0: Disabled Privacy ExtensionsNET: Registered protocol family 17802.1Q VLAN Support v1.8 Ben Greear <[email protected]>All bugs added by David S. Miller <[email protected]>Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)Spare area=64 eccbytes 56, ecc bytes located at:2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63Available 7 bytes at (off,len):(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)Scanning device for bad blocksOptions: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,Creating 2 MTD partitions on "brcmnand":0x000003200000-0x000007b00000 : "brcmnand"0x000007b00000-0x000008000000 : "OpenVPN"SQUASHFS error: Xattrs in filesystem, these will be ignoredVFS: Mounted root (squashfs filesystem) readonly on device 31:3.devtmpfs: mountedFreeing init memory: 220K[sighandler]: No more events to be processed, quitting.[cleanup]: Waiting for children.[cleanup]: All children terminated.Reading board data...WSC UUID: 0xec7c03e1ee919e563d3eda60c7413130NTP synchronized date/time: Wed Feb 4 09:01:44 2004MAC address of 1st STA connected: 00-00-00-00-00-00No RF parameters! Use default.### main:1520 Set Normal Power!ctf: module license 'Proprietary' taints kernel.Disabling lock debugging due to kernel taintInitialise conn table 2048 entriesCommit new ethernet config...Doing nvram commit by pid 1 !et_module_init: passivemode set to 0x0et_module_init: txworkq set to 0x0et_module_init: et_txq_thresh set to 0x400et_module_init: et_rxlazy_timeout set to 0x3e8et_module_init: et_rxlazy_framecnt set to 0x20fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)dhd_module_init inno wifi platform data, skipPCI_PROBE: bus 3, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0002:03:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:2985 starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth1] MAC: 00:90:4c:11:22:33dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.PCIe shared addr read took 46383 usec before dongle is readyDMA RX offset from shared Area 0bus->txmode_push is set to 0ring_info_raw: 564c 92 26 00 dc 9a 26 00 f4 9c 26 00 0c 9f 26 0018 9f 26 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 86 00 00 00max H2D queues 134dhd_bus_start: Initializing 134 flowringsdhd_bus_cmn_writeshared:0000: 00 00 7a 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 a0 35 8e 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 24 0f 8f 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 80 44 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 c0 35 8e 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 e0 35 8e 00 00 00 00dhd_bus_cmn_writeshared:0000: e0 94 13 8ddhd_bus_cmn_writeshared:0000: 08 00 00 00mac: 610 da 43 87 39 75PCI_PROBE: bus 4, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0002:04:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:2988 starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth2] MAC: 00:90:4c:11:22:33CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crcCONSOLE: 000000.035 wl0: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)CONSOLE: 000000.035 TCAM: 256 used: 135 exceed:0CONSOLE: 000000.036 reclaim section 1: Returned 119324 bytes to the heapCONSOLE:dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.PCIe shared addr read took 46383 usec before dongle is readyDMA RX offset from shared Area 0bus->txmode_push is set to 0ring_info_raw: 5628 8f 26 00 b8 97 26 00 d0 99 26 00 e8 9b 26 00f4 9b 26 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 86 00 00 00max H2D queues 134dhd_bus_start: Initializing 134 flowringsdhd_bus_cmn_writeshared:0000: 00 80 fe 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 a0 03 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 0c 0f 8f 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 c0 51 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 c0 03 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 e0 03 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: a0 d7 68 8ddhd_bus_cmn_writeshared:0000: 08 00 00 00mac: 610 da 43 87 39 74PCI_PROBE: bus 1, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0001:01:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:298b starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth3] MAC: 00:90:4c:11:22:33CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crcCONSOLE: 000000.041 wl1: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)CONSOLE: 000000.041 TCAM: 256 used: 135 exceed:0CONSOLE: 000000.042 reclaim section 1: Returned 119324 bytes to the heapCONSOLE:dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.dhdpcie_readshared: address (0xfe0901f6) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhd_bus_init :Shared area read faileddhd_bus_start, dhd_bus_init failed -1dhdpcie_init: dhd_bud_start() faileddhdpcie_readshared: address (0xfe0901f6) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhdpcie_handle_dongle_trap: Dongle(wl2) trap detected. Restarting the systemC\FCDigital core power voltage set to 1.0VDecompressing...doneDigital core power voltage set to 1.0VSHMOO VER 1.13PKID07DC06011801080000000000001A103F01000000S300001EF000014A0RDLYW0 00000004RDENW0 00000037RDQSW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----02 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------03 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------04 --++++++++++++++++++++++++X++++++++++++++++++++++++-------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 --------++++++++++++++++++++++++++++X+++++++++++++++++++++++++--08 --------++++++++++++++++++++++X++++++++++++++++++++++-----------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------11 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--12 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------13 ---------------++++++++++++++++++++++X++++++++++++++++++++++----14 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------15 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--P\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------01 --+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----02 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------03 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------04 +++++++++++++++++++++++++++X++++++++++++++++++++++++++----------05 -+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------07 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--08 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------09 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++10 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------11 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--12 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------13 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----14 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------15 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--N\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 -------+++++++++++++++++++++++++++X++++++++++++++++++++++++++---02 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------03 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------04 -+++++++++++++++++++++++++X+++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++--08 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------09 ----------------++++++++++++++++++++++++X+++++++++++++++++++++++10 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------11 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-12 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++-------13 ---------------++++++++++++++++++++++++X++++++++++++++++++++++--14 ----------++++++++++++++++++++++++X++++++++++++++++++++++++-----15 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++WRDQW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-01 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-------+++-02 +++++++++++++++++++++++++X++++++++++++++++++++++++------+++++++-03 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-04 +++++++++++++++++++++++X++++++++++++++++++++++----------+++++++-05 +++++++++++++++++++++++++X+++++++++++++++++++++++++-----+++++++-06 +++++++++++++++++++++++X+++++++++++++++++++++++----------++++++-07 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-08 ++++++++++++++++++++++++X++++++++++++++++++++++++--------++++++-09 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------10 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-11 ---+++++++++++++++++++++++++X++++++++++++++++++++++++-----------12 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------+++++-13 --+++++++++++++++++++++++++X+++++++++++++++++++++++++-----------14 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-15 ---+++++++++++++++++++++++++X++++++++++++++++++++++++-----------WRDMW0 00000024WRDMW0 00000026ADDR0000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ++++++++++++++++++++S++++++++++X++++++++++++++++++++++++++++++++Decompressing...doneCFE for Foxconn Router R8000 version: v1.0.8Build Date: Fri May 30 15:03:06 CST 2014Init ArenaInit Devs.Boot up from NAND flash...Bootcode Boot partition size = 524288(0x80000)DDR Clock: 800 MHzInfo: DDR frequency set from clkfreq=1000,*800*et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)CPU type 0x0: 1000MHzTot mem: 262144 KBytesDevice eth0: hwaddr 10-DA-43-87-39-76, ipaddr 192.168.1.1, mask 255.255.255.0gateway not set, nameserver not setChecking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)Loading: ..... 4982560 bytes readEntry at 0x00008000Closing network.Starting program at 0x00008000console [ttyS0] enabled, bootconsole disabledserial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550brd: module loadedloop: module loadedpflash: found no supported devicesbcmsflash: found no supported devicesBoot partition size = 524288(0x80000)lookup_nflash_rootfs_offset: offset = 0x200000nflash: squash filesystem with lzma found at block 31Creating 17 MTD partitions on "nflash":0x000000000000-0x000000080000 : "boot"0x000000080000-0x000000200000 : "nvram"0x000000200000-0x000002600000 : "linux"0x0000003eef20-0x000002600000 : "rootfs"0x000002600000-0x000002680000 : "board_data"0x000002680000-0x000002780000 : "POT1"0x000002780000-0x000002880000 : "POT2"0x000002880000-0x000002b40000 : "T_Meter1"0x000002b40000-0x000002e00000 : "T_Meter2"0x000002e00000-0x000002e80000 : "ML1"0x000002e80000-0x000002f00000 : "ML2"0x000002f00000-0x000002f80000 : "ML3"0x000002f80000-0x000003000000 : "ML4"0x000003000000-0x000003080000 : "ML5"0x000003080000-0x000003100000 : "ML6"0x000003100000-0x000003180000 : "ML7"0x000003180000-0x000003200000 : "QoSRule"PPP generic driver version 2.4.2NET: Registered protocol family 24PPPoL2TP kernel driver, V0.17tun: Universal TUN/TAP device driver, 1.6tun: (C) 1999-2004 Max Krasnyansky <[email protected]>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driverehci_hcd 0000:00:0b.1: EHCI Host Controllerehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00hub 1-0:1.0: USB hub foundhub 1-0:1.0: 2 ports detectedohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driverohci_hcd 0000:00:0b.0: OHCI Host Controllerohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000hub 2-0:1.0: USB hub foundhub 2-0:1.0: 2 ports detectedxhci_hcd 0000:00:0c.0: xHCI Host Controllerxhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000xhci_hcd 0000:00:0c.0: Failed to enable MSI-Xxhci_hcd 0000:00:0c.0: failed to allocate MSI entryusb usb3: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum valuesxHCI xhci_add_endpoint called for root hubxHCI xhci_check_bandwidth called for root hubhub 3-0:1.0: USB hub foundhub 3-0:1.0: 1 port detectedcsw_retry 100Initializing USB Mass Storage driver...usbcore: registered new interface driver usb-storageUSB Mass Storage support registered.u32 classifierActions configurednf_conntrack version 0.5.0 (3979 buckets, 15916 max)ip_tables: (C) 2000-2006 Netfilter Core TeamTCP cubic registeredNET: Registered protocol family 10lo: Disabled Privacy ExtensionsIPv6 over IPv4 tunneling driversit0: Disabled Privacy Extensionsip6tnl0: Disabled Privacy ExtensionsNET: Registered protocol family 17802.1Q VLAN Support v1.8 Ben Greear <[email protected]>All bugs added by David S. Miller <[email protected]>Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)Spare area=64 eccbytes 56, ecc bytes located at:2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63Available 7 bytes at (off,len):(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)Scanning device for bad blocksOptions: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,Creating 2 MTD partitions on "brcmnand":0x000003200000-0x000007b00000 : "brcmnand"0x000007b00000-0x000008000000 : "OpenVPN"SQUASHFS error: Xattrs in filesystem, these will be ignoredVFS: Mounted root (squashfs filesystem) readonly on device 31:3.devtmpfs: mountedFreeing init memory: 220K[sighandler]: No more events to be processed, quitting.[cleanup]: Waiting for children.[cleanup]: All children terminated.Reading board data...WSC UUID: 0xec7c03e1ee919e563d3eda60c7413130NTP synchronized date/time: Sat Feb 7 01:52:56 2004MAC address of 1st STA connected: 00-00-00-00-00-00No RF parameters! Use default.### main:1520 Set Normal Power!ctf: module license 'Proprietary' taints kernel.Disabling lock debugging due to kernel taintInitialise conn table 2048 entrieset_module_init: passivemode set to 0x0et_module_init: txworkq set to 0x0et_module_init: et_txq_thresh set to 0x400et_module_init: et_rxlazy_timeout set to 0x3e8et_module_init: et_rxlazy_framecnt set to 0x20fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)dhd_module_init inno wifi platform data, skipPCI_PROBE: bus 3, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0002:03:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:2985 starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth1] MAC: 00:90:4c:11:22:33dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.PCIe shared addr read took 46383 usec before dongle is readyDMA RX offset from shared Area 0bus->txmode_push is set to 0ring_info_raw: 564c 92 26 00 dc 9a 26 00 f4 9c 26 00 0c 9f 26 0018 9f 26 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 86 00 00 00max H2D queues 134dhd_bus_start: Initializing 134 flowringsdhd_bus_cmn_writeshared:0000: 00 00 1a 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 60 37 8e 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 94 46 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 40 17 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 80 1b 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 a0 1b 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 28 60 8ddhd_bus_cmn_writeshared:0000: 08 00 00 00mac: 610 da 43 87 39 75PCI_PROBE: bus 4, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0002:04:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:2988 starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth2] MAC: 00:90:4c:11:22:33CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crcCONSOLE: 000000.036 wl0: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)CONSOLE: 000000.036 TCAM: 256 used: 135 exceed:0CONSOLE: 000000.037 reclaim section 1: Returned 119324 bytes to the heapCONSOLE:dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.PCIe shared addr read took 46383 usec before dongle is readyDMA RX offset from shared Area 0bus->txmode_push is set to 0ring_info_raw: 5628 8f 26 00 b8 97 26 00 d0 99 26 00 e8 9b 26 00f4 9b 26 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 86 00 00 00max H2D queues 134dhd_bus_start: Initializing 134 flowringsdhd_bus_cmn_writeshared:0000: 00 00 fc 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 80 fa 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 ac 46 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 c0 fb 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 a0 fa 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 c0 fa 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: e0 45 ae 8fdhd_bus_cmn_writeshared:0000: 08 00 00 00mac: 610 da 43 87 39 74PCI_PROBE: bus 1, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0001:01:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:298b starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth3] MAC: 00:90:4c:11:22:33CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crcCONSOLE: 000000.041 wl1: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)CONSOLE: 000000.041 TCAM: 256 used: 135 exceed:0CONSOLE: 000000.042 reclaim section 1: Returned 119324 bytes to the heapCONSOLE:dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.dhdpcie_readshared: address (0xfe0d01f2) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhd_bus_init :Shared area read faileddhd_bus_start, dhd_bus_init failed -1dhdpcie_init: dhd_bud_start() faileddhdpcie_readshared: address (0xfe0d01f2) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhdpcie_handle_dongle_trap: Dongle(wl2) trap detected. Restarting the systemC\FCDigital core power voltage set to 1.0VDecompressing...doneDigital core power voltage set to 1.0VSHMOO VER 1.13PKID07DC06011801080000000000001A103F01000000S300001EB000014C0RDLYW0 00000004RDENW0 00000037RDQSW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----02 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------03 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------04 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++--08 --------++++++++++++++++++++++X++++++++++++++++++++++-----------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 ---------+++++++++++++++++++++++X++++++++++++++++++++++---------11 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--12 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------13 --------------+++++++++++++++++++++++X++++++++++++++++++++++----14 -----------+++++++++++++++++++++++X++++++++++++++++++++++-------15 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--P\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------01 ---++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-----02 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------03 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------04 +++++++++++++++++++++++++++X++++++++++++++++++++++++++----------05 -+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------07 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--08 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------09 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++10 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------11 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--12 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------13 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----14 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------15 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--N\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 -------+++++++++++++++++++++++++++X++++++++++++++++++++++++++---02 -----++++++++++++++++++++++++++X++++++++++++++++++++++++++------03 -----+++++++++++++++++++++++++X+++++++++++++++++++++++++--------04 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 ---------+++++++++++++++++++++++++++X++++++++++++++++++++++++++-08 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------11 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-12 -------+++++++++++++++++++++++++X++++++++++++++++++++++++-------13 ---------------++++++++++++++++++++++++X++++++++++++++++++++++--14 -----------++++++++++++++++++++++++X++++++++++++++++++++++++----15 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-WRDQW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-01 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-02 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-03 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-04 +++++++++++++++++++++++X++++++++++++++++++++++-----------++++++-05 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-06 +++++++++++++++++++++++X+++++++++++++++++++++++----------++++++-07 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-08 ++++++++++++++++++++++++X+++++++++++++++++++++++----------+++++-09 -+++++++++++++++++++++++++X+++++++++++++++++++++++++------------10 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-11 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------12 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-13 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------14 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-15 --+++++++++++++++++++++++++X+++++++++++++++++++++++++-----------WRDMW0 00000024WRDMW0 00000026ADDR0000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ++++++++++++++++++++S++++++++++X++++++++++++++++++++++++++++++++Decompressing...doneCFE for Foxconn Router R8000 version: v1.0.8Build Date: Fri May 30 15:03:06 CST 2014Init ArenaInit Devs.Boot up from NAND flash...Bootcode Boot partition size = 524288(0x80000)DDR Clock: 800 MHzInfo: DDR frequency set from clkfreq=1000,*800*et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)CPU type 0x0: 1000MHzTot mem: 262144 KBytesDevice eth0: hwaddr 10-DA-43-87-39-76, ipaddr 192.168.1.1, mask 255.255.255.0gateway not set, nameserver not setChecking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)Loading: ..... 4982560 bytes readEntry at 0x00008000Closing network.Starting program at 0x00008000console [ttyS0] enabled, bootconsole disabledserial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550brd: module loadedloop: module loadedpflash: found no supported devicesbcmsflash: found no supported devicesBoot partition size = 524288(0x80000)lookup_nflash_rootfs_offset: offset = 0x200000nflash: squash filesystem with lzma found at block 31Creating 17 MTD partitions on "nflash":0x000000000000-0x000000080000 : "boot"0x000000080000-0x000000200000 : "nvram"0x000000200000-0x000002600000 : "linux"0x0000003eef20-0x000002600000 : "rootfs"0x000002600000-0x000002680000 : "board_data"0x000002680000-0x000002780000 : "POT1"0x000002780000-0x000002880000 : "POT2"0x000002880000-0x000002b40000 : "T_Meter1"0x000002b40000-0x000002e00000 : "T_Meter2"0x000002e00000-0x000002e80000 : "ML1"0x000002e80000-0x000002f00000 : "ML2"0x000002f00000-0x000002f80000 : "ML3"0x000002f80000-0x000003000000 : "ML4"0x000003000000-0x000003080000 : "ML5"0x000003080000-0x000003100000 : "ML6"0x000003100000-0x000003180000 : "ML7"0x000003180000-0x000003200000 : "QoSRule"PPP generic driver version 2.4.2NET: Registered protocol family 24PPPoL2TP kernel driver, V0.17tun: Universal TUN/TAP device driver, 1.6tun: (C) 1999-2004 Max Krasnyansky <[email protected]>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driverehci_hcd 0000:00:0b.1: EHCI Host Controllerehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00hub 1-0:1.0: USB hub foundhub 1-0:1.0: 2 ports detectedohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driverohci_hcd 0000:00:0b.0: OHCI Host Controllerohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000hub 2-0:1.0: USB hub foundhub 2-0:1.0: 2 ports detectedxhci_hcd 0000:00:0c.0: xHCI Host Controllerxhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000xhci_hcd 0000:00:0c.0: Failed to enable MSI-Xxhci_hcd 0000:00:0c.0: failed to allocate MSI entryusb usb3: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum valuesxHCI xhci_add_endpoint called for root hubxHCI xhci_check_bandwidth called for root hubhub 3-0:1.0: USB hub foundhub 3-0:1.0: 1 port detectedcsw_retry 100Initializing USB Mass Storage driver...usbcore: registered new interface driver usb-storageUSB Mass Storage support registered.u32 classifierActions configurednf_conntrack version 0.5.0 (3979 buckets, 15916 max)ip_tables: (C) 2000-2006 Netfilter Core TeamTCP cubic registeredNET: Registered protocol family 10lo: Disabled Privacy ExtensionsIPv6 over IPv4 tunneling driversit0: Disabled Privacy Extensionsip6tnl0: Disabled Privacy ExtensionsNET: Registered protocol family 17802.1Q VLAN Support v1.8 Ben Greear <[email protected]>All bugs added by David S. Miller <[email protected]>Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)Spare area=64 eccbytes 56, ecc bytes located at:2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63Available 7 bytes at (off,len):(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)Scanning device for bad blocksOptions: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,Creating 2 MTD partitions on "brcmnand":0x000003200000-0x000007b00000 : "brcmnand"0x000007b00000-0x000008000000 : "OpenVPN"SQUASHFS error: Xattrs in filesystem, these will be ignoredVFS: Mounted root (squashfs filesystem) readonly on device 31:3.devtmpfs: mountedFreeing init memory: 220K[sighandler]: No more events to be processed, quitting.[cleanup]: Waiting for children.[cleanup]: All children terminated.Reading board data...WSC UUID: 0xec7c03e1ee919e563d3eda60c7413130NTP synchronized date/time: Sun Feb 1 20:43:36 2004MAC address of 1st STA connected: 00-00-00-00-00-00No RF parameters! Use default.### main:1520 Set Normal Power!ctf: module license 'Proprietary' taints kernel.Disabling lock debugging due to kernel taintInitialise conn table 2048 entrieset_module_init: passivemode set to 0x0et_module_init: txworkq set to 0x0et_module_init: et_txq_thresh set to 0x400et_module_init: et_rxlazy_timeout set to 0x3e8et_module_init: et_rxlazy_framecnt set to 0x20fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)dhd_module_init inno wifi platform data, skipPCI_PROBE: bus 3, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0002:03:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:2985 starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth1] MAC: 00:90:4c:11:22:33dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.PCIe shared addr read took 46383 usec before dongle is readyDMA RX offset from shared Area 0bus->txmode_push is set to 0ring_info_raw: 564c 92 26 00 dc 9a 26 00 f4 9c 26 00 0c 9f 26 0018 9f 26 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 86 00 00 00max H2D queues 134dhd_bus_start: Initializing 134 flowringsdhd_bus_cmn_writeshared:0000: 00 00 77 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 a0 be 8f 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 14 a4 8e 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 00 4f 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 c0 be 8f 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 e0 be 8f 00 00 00 00dhd_bus_cmn_writeshared:0000: c0 b6 0c 8fdhd_bus_cmn_writeshared:0000: 08 00 00 00mac: 610 da 43 87 39 75PCI_PROBE: bus 4, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0002:04:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:2988 starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth2] MAC: 00:90:4c:11:22:33CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crcCONSOLE: 000000.035 wl0: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)CONSOLE: 000000.035 TCAM: 256 used: 135 exceed:0CONSOLE: 000000.036 reclaim section 1: Returned 119324 bytes to the heapCONSOLE:dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.PCIe shared addr read took 46383 usec before dongle is readyDMA RX offset from shared Area 0bus->txmode_push is set to 0ring_info_raw: 5628 8f 26 00 b8 97 26 00 d0 99 26 00 e8 9b 26 00f4 9b 26 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 86 00 00 00max H2D queues 134dhd_bus_start: Initializing 134 flowringsdhd_bus_cmn_writeshared:0000: 00 00 fc 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 40 38 8e 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 58 45 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 40 fb 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 60 38 8e 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 80 fc 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 40 88 43 8ddhd_bus_cmn_writeshared:0000: 08 00 00 00mac: 610 da 43 87 39 74PCI_PROBE: bus 1, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0001:01:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:298b starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth3] MAC: 00:90:4c:11:22:33CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crcCONSOLE: 000000.041 wl1: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)CONSOLE: 000000.041 TCAM: 256 used: 135 exceed:0CONSOLE: 000000.042 reclaim section 1: Returned 119324 bytes to the heapCONSOLE:dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.dhdpcie_readshared: address (0xfe1101ee) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhd_bus_init :Shared area read faileddhd_bus_start, dhd_bus_init failed -1dhdpcie_init: dhd_bud_start() faileddhdpcie_readshared: address (0xfe1101ee) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhdpcie_handle_dongle_trap: Dongle(wl2) trap detected. Restarting the systemC\FCDigital core power voltage set to 1.0VDecompressing...doneDigital core power voltage set to 1.0VDecompressing...doneDigital core power voltage set to 1.0VSHMOO VER 1.13PKID07DC06011801080000000000001A103F01000000S300001EF000014F0RDLYW0 00000004RDENW0 00000037RDQSW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----02 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------03 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 ---------+++++++++++++++++++++++++++X++++++++++++++++++++++++++-08 -------+++++++++++++++++++++++X++++++++++++++++++++++-----------09 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++10 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------11 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--12 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------13 --------------+++++++++++++++++++++++X++++++++++++++++++++++----14 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------15 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--P\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------01 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----02 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------03 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------04 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------05 --+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------07 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--08 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------09 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++10 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------11 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--12 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------13 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----14 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------15 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--N\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 ------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++---02 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------03 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------04 --++++++++++++++++++++++++X++++++++++++++++++++++++-------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 --------++++++++++++++++++++++++++++X++++++++++++++++++++++++++-08 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------09 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++10 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------11 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-12 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++-------13 ---------------++++++++++++++++++++++++X+++++++++++++++++++++++-14 ----------+++++++++++++++++++++++++X++++++++++++++++++++++++----15 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++WRDQW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------+++++-01 ++++++++++++++++++++++++++X+++++++++++++++++++++++++---------++-02 +++++++++++++++++++++++++X++++++++++++++++++++++++--------+++++-03 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------+++++-04 ++++++++++++++++++++++X++++++++++++++++++++++-------------+++++-05 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-----++++++-06 ++++++++++++++++++++++++X+++++++++++++++++++++++---------++++++-07 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-08 ++++++++++++++++++++++++X++++++++++++++++++++++++---------+++++-09 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------10 +++++++++++++++++++++++++X+++++++++++++++++++++++++-+-------+++-11 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------12 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-13 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------14 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-15 ---+++++++++++++++++++++++++X++++++++++++++++++++++++-----------WRDMW0 00000024WRDMW0 00000026ADDR0000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ++++++++++++++++++++S++++++++++X++++++++++++++++++++++++++++++++Decompressing...doneCFE for Foxconn Router R8000 version: v1.0.8Build Date: Fri May 30 15:03:06 CST 2014Init ArenaInit Devs.Boot up from NAND flash...Bootcode Boot partition size = 524288(0x80000)DDR Clock: 800 MHzInfo: DDR frequency set from clkfreq=1000,*800*et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)CPU type 0x0: 1000MHzTot mem: 262144 KBytesDevice eth0: hwaddr 10-DA-43-87-39-76, ipaddr 192.168.1.1, mask 255.255.255.0gateway not set, nameserver not setStartup canceledCFE> ^CCFE> ^CCFE> ^CCFE> ^CCFE> ^CCFE> ^CCFE> tftpdStart TFTP serverReading :: Done. 31223866 bytes readProgramming...done. 31223866 bytes writtenSkip writing CHK checksum for nflash.Digital core power voltage set to 1.0VDecompressing...doneDigital core power voltage set to 1.0VSHMOO VER 1.13PKID07DC06011801080000000000001A103F01000000S300001EB000014C0RDLYW0 00000004RDENW0 00000037RDQSW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----02 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------03 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++--08 --------++++++++++++++++++++++X++++++++++++++++++++++-----------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------11 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--12 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------13 --------------+-++++++++++++++++++++++X+++++++++++++++++++++----14 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------15 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--P\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------01 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----02 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------03 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------04 +++++++++++++++++++++++++++X++++++++++++++++++++++++++----------05 -+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------07 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--08 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------09 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++10 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------11 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--12 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------13 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----14 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------15 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--N\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --+++++++++++++++++++++++++++X++++++++++++++++++++++++++--------01 ------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++---02 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------03 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------04 --++++++++++++++++++++++++X++++++++++++++++++++++++-------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ----++++++++++++++++++++++++X+++++++++++++++++++++++------------07 --------++++++++++++++++++++++++++++X++++++++++++++++++++++++++-08 -------+++++++++++++++++++++++++X+++++++++++++++++++++++++------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------11 ---------------++++++++++++++++++++++++X+++++++++++++++++++++++-12 -------+++++++++++++++++++++++++X++++++++++++++++++++++++-------13 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-14 ----------+++++++++++++++++++++++++X++++++++++++++++++++++++----15 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++WRDQW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-01 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-02 +++++++++++++++++++++++++X++++++++++++++++++++++++--------+++++-03 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-04 +++++++++++++++++++++++X++++++++++++++++++++++-----------++++++-05 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-----++++++-06 +++++++++++++++++++++++X+++++++++++++++++++++++----------++++++-07 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-08 ++++++++++++++++++++++++X++++++++++++++++++++++++---------+++++-09 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------10 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-11 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------12 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-13 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------14 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-15 ---+++++++++++++++++++++++++X++++++++++++++++++++++++-----------WRDMW0 00000024WRDMW0 00000026ADDR0000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ++++++++++++++++++++S++++++++++X++++++++++++++++++++++++++++++++Decompressing...doneCFE for Foxconn Router R8000 version: v1.0.8Build Date: Fri May 30 15:03:06 CST 2014Init ArenaInit Devs.Boot up from NAND flash...Bootcode Boot partition size = 524288(0x80000)DDR Clock: 800 MHzInfo: DDR frequency set from clkfreq=1000,*800*et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)CPU type 0x0: 1000MHzTot mem: 262144 KBytesDevice eth0: hwaddr 10-DA-43-87-39-76, ipaddr 192.168.1.1, mask 255.255.255.0gateway not set, nameserver not setChecking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)Loading: ..... 4982560 bytes readEntry at 0x00008000Closing network.Starting program at 0x00008000console [ttyS0] enabled, bootconsole disabledserial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550brd: module loadedloop: module loadedpflash: found no supported devicesbcmsflash: found no supported devicesBoot partition size = 524288(0x80000)lookup_nflash_rootfs_offset: offset = 0x200000nflash: squash filesystem with lzma found at block 31Creating 17 MTD partitions on "nflash":0x000000000000-0x000000080000 : "boot"0x000000080000-0x000000200000 : "nvram"0x000000200000-0x000002600000 : "linux"0x0000003eef20-0x000002600000 : "rootfs"0x000002600000-0x000002680000 : "board_data"0x000002680000-0x000002780000 : "POT1"0x000002780000-0x000002880000 : "POT2"0x000002880000-0x000002b40000 : "T_Meter1"0x000002b40000-0x000002e00000 : "T_Meter2"0x000002e00000-0x000002e80000 : "ML1"0x000002e80000-0x000002f00000 : "ML2"0x000002f00000-0x000002f80000 : "ML3"0x000002f80000-0x000003000000 : "ML4"0x000003000000-0x000003080000 : "ML5"0x000003080000-0x000003100000 : "ML6"0x000003100000-0x000003180000 : "ML7"0x000003180000-0x000003200000 : "QoSRule"PPP generic driver version 2.4.2NET: Registered protocol family 24PPPoL2TP kernel driver, V0.17tun: Universal TUN/TAP device driver, 1.6tun: (C) 1999-2004 Max Krasnyansky <[email protected]>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driverehci_hcd 0000:00:0b.1: EHCI Host Controllerehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00hub 1-0:1.0: USB hub foundhub 1-0:1.0: 2 ports detectedohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driverohci_hcd 0000:00:0b.0: OHCI Host Controllerohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000hub 2-0:1.0: USB hub foundhub 2-0:1.0: 2 ports detectedxhci_hcd 0000:00:0c.0: xHCI Host Controllerxhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000xhci_hcd 0000:00:0c.0: Failed to enable MSI-Xxhci_hcd 0000:00:0c.0: failed to allocate MSI entryusb usb3: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum valuesxHCI xhci_add_endpoint called for root hubxHCI xhci_check_bandwidth called for root hubhub 3-0:1.0: USB hub foundhub 3-0:1.0: 1 port detectedcsw_retry 100Initializing USB Mass Storage driver...usbcore: registered new interface driver usb-storageUSB Mass Storage support registered.u32 classifierActions configurednf_conntrack version 0.5.0 (3979 buckets, 15916 max)ip_tables: (C) 2000-2006 Netfilter Core TeamTCP cubic registeredNET: Registered protocol family 10lo: Disabled Privacy ExtensionsIPv6 over IPv4 tunneling driversit0: Disabled Privacy Extensionsip6tnl0: Disabled Privacy ExtensionsNET: Registered protocol family 17802.1Q VLAN Support v1.8 Ben Greear <[email protected]>All bugs added by David S. Miller <[email protected]>Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)Spare area=64 eccbytes 56, ecc bytes located at:2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63Available 7 bytes at (off,len):(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)Scanning device for bad blocksOptions: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,Creating 2 MTD partitions on "brcmnand":0x000003200000-0x000007b00000 : "brcmnand"0x000007b00000-0x000008000000 : "OpenVPN"SQUASHFS error: Xattrs in filesystem, these will be ignoredVFS: Mounted root (squashfs filesystem) readonly on device 31:3.devtmpfs: mountedFreeing init memory: 220K[sighandler]: No more events to be processed, quitting.[cleanup]: Waiting for children.[cleanup]: All children terminated.Reading board data...WSC UUID: 0xec7c03e1ee919e563d3eda60c7413130NTP synchronized date/time: Mon Feb 2 18:20:40 2004MAC address of 1st STA connected: 00-00-00-00-00-00No RF parameters! Use default.### main:1520 Set Normal Power!ctf: module license 'Proprietary' taints kernel.Disabling lock debugging due to kernel taintInitialise conn table 2048 entrieset_module_init: passivemode set to 0x0et_module_init: txworkq set to 0x0et_module_init: et_txq_thresh set to 0x400et_module_init: et_rxlazy_timeout set to 0x3e8et_module_init: et_rxlazy_framecnt set to 0x20fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)dhd_module_init inno wifi platform data, skipPCI_PROBE: bus 3, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0002:03:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:2987 starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth1] MAC: 00:90:4c:11:22:33dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.PCIe shared addr read took 56383 usec before dongle is readyDMA RX offset from shared Area 0bus->txmode_push is set to 0ring_info_raw: 564c 92 26 00 dc 9a 26 00 f4 9c 26 00 0c 9f 26 0018 9f 26 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 86 00 00 00max H2D queues 134dhd_bus_start: Initializing 134 flowringsdhd_bus_cmn_writeshared:0000: 00 80 5b 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 80 10 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 74 11 8f 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 40 10 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 a0 10 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 c0 10 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 44 a8 8fdhd_bus_cmn_writeshared:0000: 08 00 00 00mac: 610 da 43 87 39 75PCI_PROBE: bus 4, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0002:04:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:298a starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth2] MAC: 00:90:4c:11:22:33CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crcCONSOLE: 000000.035 wl0: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)CONSOLE: 000000.035 TCAM: 256 used: 135 exceed:0CONSOLE: 000000.036 reclaim section 1: Returned 119324 bytes to the heapCONSOLE:dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.PCIe shared addr read took 46383 usec before dongle is readyDMA RX offset from shared Area 0bus->txmode_push is set to 0ring_info_raw: 5628 8f 26 00 b8 97 26 00 d0 99 26 00 e8 9b 26 00f4 9b 26 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 86 00 00 00max H2D queues 134dhd_bus_start: Initializing 134 flowringsdhd_bus_cmn_writeshared:0000: 00 00 fe 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 60 37 8e 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 7c 11 8f 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 c0 44 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 80 fe 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 a0 fe 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 80 41 a8 8fdhd_bus_cmn_writeshared:0000: 08 00 00 00mac: 610 da 43 87 39 74PCI_PROBE: bus 1, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0001:01:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:298d starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth3] MAC: 00:90:4c:11:22:33CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crcCONSOLE: 000000.041 wl1: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)CONSOLE: 000000.041 TCAM: 256 used: 135 exceed:0CONSOLE: 000000.042 reclaim section 1: Returned 119324 bytes to the heapCONSOLE:dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.dhdpcie_readshared: address (0xfe0b01f4) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhd_bus_init :Shared area read faileddhd_bus_start, dhd_bus_init failed -1dhdpcie_init: dhd_bud_start() faileddhdpcie_readshared: address (0xfe0b01f4) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhdpcie_handle_dongle_trap: Dongle(wl2) trap detected. Restarting the systemC\F8Digital core power voltage set to 1.0VDecompressing...doneDigital core power voltage set to 1.0VSHMOO VER 1.13PKID07DC06011801080000000000001A103F01000000S300001EB00001500RDLYW0 00000004RDENW0 00000038RDQSW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----02 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------03 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------07 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++--08 --------++++++++++++++++++++++X++++++++++++++++++++++-----------09 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++10 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------11 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--12 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------13 --------------+-++++++++++++++++++++++X+++++++++++++++++++++----14 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------15 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--P\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------01 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----02 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------03 -+++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------04 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------05 -+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------07 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--08 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------09 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++10 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------11 ---++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++-12 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------13 ----++++++++++++++++++++++++++++X+++++++++++++++++++++++++++----14 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------15 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--N\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ---++++++++++++++++++++++++++X+++++++++++++++++++++++++---------01 ------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++---02 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------03 ----+++++++++++++++++++++++++X+++++++++++++++++++++++++---------04 --++++++++++++++++++++++++X++++++++++++++++++++++++-------------05 ------++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 --------++++++++++++++++++++++++++++X++++++++++++++++++++++++++-08 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------11 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-12 -------+++++++++++++++++++++++++X++++++++++++++++++++++++-------13 ----------------++++++++++++++++++++++++X+++++++++++++++++++++--14 ----------+++++++++++++++++++++++++X++++++++++++++++++++++++----15 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++WRDQW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-01 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-02 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-03 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-04 ++++++++++++++++++++++X++++++++++++++++++++++------------++++++-05 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-06 +++++++++++++++++++++++X+++++++++++++++++++++++----------++++++-07 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-08 ++++++++++++++++++++++++X+++++++++++++++++++++++----------+++++-09 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------10 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-11 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------12 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-13 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------14 +++++++++++++++++++++++++X+++++++++++++++++++++++++--------++++-15 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------WRDMW0 00000024WRDMW0 00000026ADDR0000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 +++++++++++++++++++++S+++++++++X++++++++++++++++++++++++++++++++Decompressing...doneCFE for Foxconn Router R8000 version: v1.0.8Build Date: Fri May 30 15:03:06 CST 2014Init ArenaInit Devs.Boot up from NAND flash...Bootcode Boot partition size = 524288(0x80000)DDR Clock: 800 MHzInfo: DDR frequency set from clkfreq=1000,*800*et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)CPU type 0x0: 1000MHzTot mem: 262144 KBytesDevice eth0: hwaddr 10-DA-43-87-39-76, ipaddr 192.168.1.1, mask 255.255.255.0gateway not set, nameserver not setChecking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)Loading: ..... 4982560 bytes readEntry at 0x00008000Closing network.Starting program at 0x00008000console [ttyS0] enabled, bootconsole disabledserial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550brd: module loadedloop: module loadedpflash: found no supported devicesbcmsflash: found no supported devicesBoot partition size = 524288(0x80000)lookup_nflash_rootfs_offset: offset = 0x200000nflash: squash filesystem with lzma found at block 31Creating 17 MTD partitions on "nflash":0x000000000000-0x000000080000 : "boot"0x000000080000-0x000000200000 : "nvram"0x000000200000-0x000002600000 : "linux"0x0000003eef20-0x000002600000 : "rootfs"0x000002600000-0x000002680000 : "board_data"0x000002680000-0x000002780000 : "POT1"0x000002780000-0x000002880000 : "POT2"0x000002880000-0x000002b40000 : "T_Meter1"0x000002b40000-0x000002e00000 : "T_Meter2"0x000002e00000-0x000002e80000 : "ML1"0x000002e80000-0x000002f00000 : "ML2"0x000002f00000-0x000002f80000 : "ML3"0x000002f80000-0x000003000000 : "ML4"0x000003000000-0x000003080000 : "ML5"0x000003080000-0x000003100000 : "ML6"0x000003100000-0x000003180000 : "ML7"0x000003180000-0x000003200000 : "QoSRule"PPP generic driver version 2.4.2NET: Registered protocol family 24PPPoL2TP kernel driver, V0.17tun: Universal TUN/TAP device driver, 1.6tun: (C) 1999-2004 Max Krasnyansky <[email protected]>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driverehci_hcd 0000:00:0b.1: EHCI Host Controllerehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00hub 1-0:1.0: USB hub foundhub 1-0:1.0: 2 ports detectedohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driverohci_hcd 0000:00:0b.0: OHCI Host Controllerohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000hub 2-0:1.0: USB hub foundhub 2-0:1.0: 2 ports detectedxhci_hcd 0000:00:0c.0: xHCI Host Controllerxhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000xhci_hcd 0000:00:0c.0: Failed to enable MSI-Xxhci_hcd 0000:00:0c.0: failed to allocate MSI entryusb usb3: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum valuesxHCI xhci_add_endpoint called for root hubxHCI xhci_check_bandwidth called for root hubhub 3-0:1.0: USB hub foundhub 3-0:1.0: 1 port detectedcsw_retry 100Initializing USB Mass Storage driver...usbcore: registered new interface driver usb-storageUSB Mass Storage support registered.u32 classifierActions configurednf_conntrack version 0.5.0 (3979 buckets, 15916 max)ip_tables: (C) 2000-2006 Netfilter Core TeamTCP cubic registeredNET: Registered protocol family 10lo: Disabled Privacy ExtensionsIPv6 over IPv4 tunneling driversit0: Disabled Privacy Extensionsip6tnl0: Disabled Privacy ExtensionsNET: Registered protocol family 17802.1Q VLAN Support v1.8 Ben Greear <[email protected]>All bugs added by David S. Miller <[email protected]>Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)Spare area=64 eccbytes 56, ecc bytes located at:2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63Available 7 bytes at (off,len):(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)Scanning device for bad blocksOptions: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,Creating 2 MTD partitions on "brcmnand":0x000003200000-0x000007b00000 : "brcmnand"0x000007b00000-0x000008000000 : "OpenVPN"SQUASHFS error: Xattrs in filesystem, these will be ignoredVFS: Mounted root (squashfs filesystem) readonly on device 31:3.devtmpfs: mountedFreeing init memory: 220K[sighandler]: No more events to be processed, quitting.[cleanup]: Waiting for children.[cleanup]: All children terminated.Reading board data...WSC UUID: 0xec7c03e1ee919e563d3eda60c7413130NTP synchronized date/time: Sat Feb 7 07:34:16 2004MAC address of 1st STA connected: 00-00-00-00-00-00No RF parameters! Use default.### main:1520 Set Normal Power!ctf: module license 'Proprietary' taints kernel.Disabling lock debugging due to kernel taintInitialise conn table 2048 entrieset_module_init: passivemode set to 0x0et_module_init: txworkq set to 0x0et_module_init: et_txq_thresh set to 0x400et_module_init: et_rxlazy_timeout set to 0x3e8et_module_init: et_rxlazy_framecnt set to 0x20fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)dhd_module_init inno wifi platform data, skipPCI_PROBE: bus 3, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0002:03:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:2987 starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth1] MAC: 00:90:4c:11:22:33dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.PCIe shared addr read took 46383 usec before dongle is readyDMA RX offset from shared Area 0bus->txmode_push is set to 0ring_info_raw: 564c 92 26 00 dc 9a 26 00 f4 9c 26 00 0c 9f 26 0018 9f 26 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 86 00 00 00max H2D queues 134dhd_bus_start: Initializing 134 flowringsdhd_bus_cmn_writeshared:0000: 00 80 1a 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 e0 35 8e 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 d0 46 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 c0 67 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 80 77 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 a0 77 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: a0 0b 45 8ddhd_bus_cmn_writeshared:0000: 08 00 00 00mac: 610 da 43 87 39 75PCI_PROBE: bus 4, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0002:04:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:298a starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth2] MAC: 00:90:4c:11:22:33CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crcCONSOLE: 000000.035 wl0: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)CONSOLE: 000000.035 TCAM: 256 used: 135 exceed:0CONSOLE: 000000.036 reclaim section 1: Returned 119324 bytes to the heapCONSOLE:dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.PCIe shared addr read took 46383 usec before dongle is readyDMA RX offset from shared Area 0bus->txmode_push is set to 0ring_info_raw: 5628 8f 26 00 b8 97 26 00 d0 99 26 00 e8 9b 26 00f4 9b 26 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 86 00 00 00max H2D queues 134dhd_bus_start: Initializing 134 flowringsdhd_bus_cmn_writeshared:0000: 00 00 fc 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 80 fa 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 e8 46 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 80 75 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 a0 fa 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 c0 fa 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 20 2d 7c 8ddhd_bus_cmn_writeshared:0000: 08 00 00 00mac: 610 da 43 87 39 74PCI_PROBE: bus 1, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0001:01:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:298d starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth3] MAC: 00:90:4c:11:22:33CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crcCONSOLE: 000000.041 wl1: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)CONSOLE: 000000.041 TCAM: 256 used: 135 exceed:0CONSOLE: 000000.042 reclaim section 1: Returned 119324 bytes to the heapCONSOLE:dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.dhdpcie_readshared: address (0xfe1101ee) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhd_bus_init :Shared area read faileddhd_bus_start, dhd_bus_init failed -1dhdpcie_init: dhd_bud_start() faileddhdpcie_readshared: address (0xfe1101ee) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhdpcie_handle_dongle_trap: Dongle(wl2) trap detected. Restarting the systemC\FCDigital core power voltage set to 1.0VDecompressing...doneDigital core power voltage set to 1.0VSHMOO VER 1.13PKID07DC06011801080000000000001A103F01000000S300001EB000014C0RDLYW0 00000004RDENW0 00000038RDQSW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------01 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----02 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------03 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------07 --------++++++++++++++++++++++++++++X+++++++++++++++++++++++++--08 --------++++++++++++++++++++++X++++++++++++++++++++++-----------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------11 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--12 ------+++++++++++++++++++++++++X++++++++++++++++++++++++--------13 ----------------++++++++++++++++++++++X+++++++++++++++++++++----14 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------15 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--P\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 -++++++++++++++++++++++++++++X+++++++++++++++++++++++++++-------01 --+++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----02 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------03 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------04 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------05 -+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++----06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------07 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--08 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------09 -----+++++++++++++++++++++++++++++X+++++++++++++++++++++++++++++10 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------11 ---++++++++++++++++++++++++++++++X++++++++++++++++++++++++++++--12 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------13 ---++++++++++++++++++++++++++++X++++++++++++++++++++++++++++----14 ++++++++++++++++++++++++++++X++++++++++++++++++++++++++++-------15 ----++++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--N\00\00\00W00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------01 -------+++++++++++++++++++++++++++X++++++++++++++++++++++++++---02 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------03 ---++++++++++++++++++++++++++X++++++++++++++++++++++++++--------04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------05 -----+++++++++++++++++++++++++++X++++++++++++++++++++++++++-----06 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------07 ---------+++++++++++++++++++++++++++X++++++++++++++++++++++++++-08 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------09 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++10 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------11 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-12 -------+++++++++++++++++++++++++X++++++++++++++++++++++++-------13 ----------------++++++++++++++++++++++++X+++++++++++++++++++++--14 -----------++++++++++++++++++++++++X++++++++++++++++++++++++----15 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-WRDQW00000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-01 ++++++++++++++++++++++++++X+++++++++++++++++++++++++--------+++-02 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-03 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------+++++-04 +++++++++++++++++++++++X++++++++++++++++++++++-----------++++++-05 +++++++++++++++++++++++++X+++++++++++++++++++++++++------++++++-06 +++++++++++++++++++++++X+++++++++++++++++++++++----------++++++-07 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-08 ++++++++++++++++++++++++X++++++++++++++++++++++++---------+++++-09 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------10 +++++++++++++++++++++++++X+++++++++++++++++++++++++--------++++-11 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------12 +++++++++++++++++++++++++X++++++++++++++++++++++++-------++++++-13 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------14 ++++++++++++++++++++++++++X+++++++++++++++++++++++++-------++++-15 ---+++++++++++++++++++++++++X++++++++++++++++++++++++-----------WRDMW0 00000024WRDMW0 00000026ADDR0000000000111111111122222222223333333333444444444455555555556666012345678901234567890123456789012345678901234567890123456789012300 ++++++++++++++++++++S++++++++++X++++++++++++++++++++++++++++++++Decompressing...doneCFE for Foxconn Router R8000 version: v1.0.8Build Date: Fri May 30 15:03:06 CST 2014Init ArenaInit Devs.Boot up from NAND flash...Bootcode Boot partition size = 524288(0x80000)DDR Clock: 800 MHzInfo: DDR frequency set from clkfreq=1000,*800*et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)CPU type 0x0: 1000MHzTot mem: 262144 KBytesDevice eth0: hwaddr 10-DA-43-87-39-76, ipaddr 192.168.1.1, mask 255.255.255.0gateway not set, nameserver not setCFE for Foxconn Router R8000 version: v1.0.8Build Date: Fri May 30 15:03:06 CST 2014Init ArenaInit Devs.Boot up from NAND flash...Bootcode Boot partition size = 524288(0x80000)DDR Clock: 800 MHzInfo: DDR frequency set from clkfreq=1000,*800*et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)CPU type 0x0: 1000MHzTot mem: 262144 KBytesDevice eth0: hwaddr 10-DA-43-87-39-76, ipaddr 192.168.1.1, mask 255.255.255.0gateway not set, nameserver not setChecking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)Loading: ..... 4982560 bytes readEntry at 0x00008000Closing network.Starting program at 0x00008000console [ttyS0] enabled, bootconsole disabledserial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117) is a 16550brd: module loadedloop: module loadedpflash: found no supported devicesbcmsflash: found no supported devicesBoot partition size = 524288(0x80000)lookup_nflash_rootfs_offset: offset = 0x200000nflash: squash filesystem with lzma found at block 31Creating 17 MTD partitions on "nflash":0x000000000000-0x000000080000 : "boot"0x000000080000-0x000000200000 : "nvram"0x000000200000-0x000002600000 : "linux"0x0000003eef20-0x000002600000 : "rootfs"0x000002600000-0x000002680000 : "board_data"0x000002680000-0x000002780000 : "POT1"0x000002780000-0x000002880000 : "POT2"0x000002880000-0x000002b40000 : "T_Meter1"0x000002b40000-0x000002e00000 : "T_Meter2"0x000002e00000-0x000002e80000 : "ML1"0x000002e80000-0x000002f00000 : "ML2"0x000002f00000-0x000002f80000 : "ML3"0x000002f80000-0x000003000000 : "ML4"0x000003000000-0x000003080000 : "ML5"0x000003080000-0x000003100000 : "ML6"0x000003100000-0x000003180000 : "ML7"0x000003180000-0x000003200000 : "QoSRule"PPP generic driver version 2.4.2NET: Registered protocol family 24PPPoL2TP kernel driver, V0.17tun: Universal TUN/TAP device driver, 1.6tun: (C) 1999-2004 Max Krasnyansky <[email protected]>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driverehci_hcd 0000:00:0b.1: EHCI Host Controllerehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00hub 1-0:1.0: USB hub foundhub 1-0:1.0: 2 ports detectedohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driverohci_hcd 0000:00:0b.0: OHCI Host Controllerohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000hub 2-0:1.0: USB hub foundhub 2-0:1.0: 2 ports detectedxhci_hcd 0000:00:0c.0: xHCI Host Controllerxhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000xhci_hcd 0000:00:0c.0: Failed to enable MSI-Xxhci_hcd 0000:00:0c.0: failed to allocate MSI entryusb usb3: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum valuesxHCI xhci_add_endpoint called for root hubxHCI xhci_check_bandwidth called for root hubhub 3-0:1.0: USB hub foundhub 3-0:1.0: 1 port detectedcsw_retry 100Initializing USB Mass Storage driver...usbcore: registered new interface driver usb-storageUSB Mass Storage support registered.u32 classifierActions configurednf_conntrack version 0.5.0 (3979 buckets, 15916 max)ip_tables: (C) 2000-2006 Netfilter Core TeamTCP cubic registeredNET: Registered protocol family 10lo: Disabled Privacy ExtensionsIPv6 over IPv4 tunneling driversit0: Disabled Privacy Extensionsip6tnl0: Disabled Privacy ExtensionsNET: Registered protocol family 17802.1Q VLAN Support v1.8 Ben Greear <[email protected]>All bugs added by David S. Miller <[email protected]>Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2012NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)Spare area=64 eccbytes 56, ecc bytes located at:2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63Available 7 bytes at (off,len):(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)Scanning device for bad blocksOptions: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,Creating 2 MTD partitions on "brcmnand":0x000003200000-0x000007b00000 : "brcmnand"0x000007b00000-0x000008000000 : "OpenVPN"SQUASHFS error: Xattrs in filesystem, these will be ignoredVFS: Mounted root (squashfs filesystem) readonly on device 31:3.devtmpfs: mountedFreeing init memory: 220K[sighandler]: No more events to be processed, quitting.[cleanup]: Waiting for children.[cleanup]: All children terminated.Reading board data...WSC UUID: 0xec7c03e1ee919e563d3eda60c7413130NTP synchronized date/time: Sun Feb 8 01:46:32 2004MAC address of 1st STA connected: 00-00-00-00-00-00No RF parameters! Use default.### main:1520 Set Normal Power!ctf: module license 'Proprietary' taints kernel.Disabling lock debugging due to kernel taintInitialise conn table 2048 entrieset_module_init: passivemode set to 0x0et_module_init: txworkq set to 0x0et_module_init: et_txq_thresh set to 0x400et_module_init: et_rxlazy_timeout set to 0x3e8et_module_init: et_rxlazy_framecnt set to 0x20fwd0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)fwd1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.7 (r478477)dhd_module_init inno wifi platform data, skipPCI_PROBE: bus 3, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0002:03:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:2985 starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth1] MAC: 00:90:4c:11:22:33dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.PCIe shared addr read took 56383 usec before dongle is readyDMA RX offset from shared Area 0bus->txmode_push is set to 0ring_info_raw: 564c 92 26 00 dc 9a 26 00 f4 9c 26 00 0c 9f 26 0018 9f 26 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 86 00 00 00max H2D queues 134dhd_bus_start: Initializing 134 flowringsdhd_bus_cmn_writeshared:0000: 00 00 7d 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 e0 a4 8e 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 58 43 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 c0 4b 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 80 7e 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 a0 7e 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 78 78 8ddhd_bus_cmn_writeshared:0000: 08 00 00 00mac: 610 da 43 87 39 75PCI_PROBE: bus 4, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0002:04:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:2988 starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth2] MAC: 00:90:4c:11:22:33CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crcCONSOLE: 000000.035 wl0: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)CONSOLE: 000000.035 TCAM: 256 used: 135 exceed:0CONSOLE: 000000.036 reclaim section 1: Returned 119324 bytes to the heapCONSOLE:dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.PCIe shared addr read took 46383 usec before dongle is readyDMA RX offset from shared Area 0bus->txmode_push is set to 0ring_info_raw: 5628 8f 26 00 b8 97 26 00 d0 99 26 00 e8 9b 26 00f4 9b 26 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0000 00 00 00 86 00 00 00max H2D queues 134dhd_bus_start: Initializing 134 flowringsdhd_bus_cmn_writeshared:0000: 00 80 fc 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 e0 7e 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 18 b6 8f 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 00 71 8d 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 00 fd 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 20 fd 8c 00 00 00 00dhd_bus_cmn_writeshared:0000: 00 11 40 8ddhd_bus_cmn_writeshared:0000: 08 00 00 00mac: 610 da 43 87 39 74PCI_PROBE: bus 1, slot 0,vendor 14E4, device AA52(good PCI location)PCI: Enabling device 0001:01:00.0 (0140 -> 0142)DHD: dongle ram size is set to 983040(orig 983040) at 0x180000dhd_attach(): thread:dhd_watchdog_thread:298b starteddhd_deferred_work_init: work queue initializeddhd_attach: wl_mbss_skipctf 1 wl_dns_skipctf 0dhd_attach: boost_pri_proto 0x03Dongle Host Driver, version 1.194.6 (r478652)Compiled in drivers/net/wireless/bcmdhd on Oct 14 2015 at 16:14:49Register interface [eth3] MAC: 00:90:4c:11:22:33CONSOLE: om_read_pci: buf[0] = 0xffff, returning bad-crcCONSOLE: 000000.041 wl1: Broadcom BCM43602 802.11 Wireless Controller 7.10.274.3.REBASE.R493518 (r532222)CONSOLE: 000000.041 TCAM: 256 used: 135 exceed:0CONSOLE: 000000.042 reclaim section 1: Returned 119324 bytes to the heapCONSOLE:dhdpcie_download_code_array: Download, Upload and compare succeeded (43602a1-roml/pcie-ag-splitrx-fdap-mbss-mfp-wl11k-wl11u-txbf-pktctx-amsdutx-ampduretry-proptxstatus, 2015.03.26.143842, 2015/03/26 14:38:42).dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.dhdpcie_readshared: address (0xfe0d01f2) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhd_bus_init :Shared area read faileddhd_bus_start, dhd_bus_init failed -1dhdpcie_init: dhd_bud_start() faileddhdpcie_readshared: address (0xfe0d01f2) of pciedev_shared invalidWaited 5006383 usec, dongle is not readydhdpcie_handle_dongle_trap: Dongle(wl2) trap detected. Restarting the systemC\FCDigital core power voltage set to 1.0VDecompressing...done
Just realized I posted the entire log...
Sorry. I know double-posts re usually frowned on, but I didn't see any way to edit my post.
This is the most recent boot only. Don't read the previous post unless you want to go through the wild journey I went through.
Stop it at the CFE prompt through serial, e.g.:
Holy Crap.
Thank you so much. I can't believe it was that easy.
I thought for sure I had a brick on my hands.
--Isaac
