I have dd-wrt installed on my netgear 6400 and i'm trying to set up a persistent VPN connection for all connected devices.
the vpn i use is iVPN and on their website they go over how to set up for dd-wrt: https://www.ivpn.net/setup/router-dd-wrt-manual.html
i followed it exactly and the vpn is not connecting upon rebooting my router.
what am i doing wrong?
here is the log for the VPN
Clientlog:
20161003 22:17:21 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161003 22:17:21 Socket Buffers: R=[180224->180224] S=[180224->180224]
20161003 22:17:21 I TCP/UDP: Preserving recently used remote address: [AF_INET]67.228.177.194:2049
20161003 22:17:21 I UDPv4 link local: [undef]
20161003 22:17:21 I UDPv4 link remote: [AF_INET]67.228.177.194:2049
20161003 22:18:21 I [UNDEF] Inactivity timeout (--ping-restart) restarting
20161003 22:18:21 I SIGUSR1[soft ping-restart] received process restarting
20161003 22:18:21 Restart pause 2 second(s)
20161003 22:18:23 W WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
20161003 22:18:23 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161003 22:18:23 Socket Buffers: R=[180224->180224] S=[180224->180224]
20161003 22:18:23 I TCP/UDP: Preserving recently used remote address: [AF_INET]67.228.177.194:2049
20161003 22:18:23 I UDPv4 link local: [undef]
20161003 22:18:23 I UDPv4 link remote: [AF_INET]67.228.177.194:2049
20161003 22:19:23 I [UNDEF] Inactivity timeout (--ping-restart) restarting
20161003 22:19:23 I SIGUSR1[soft ping-restart] received process restarting
20161003 22:19:23 Restart pause 2 second(s)
20161003 22:19:25 W WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
20161003 22:19:25 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161003 22:19:25 Socket Buffers: R=[180224->180224] S=[180224->180224]
20161003 22:19:25 I TCP/UDP: Preserving recently used remote address: [AF_INET]67.228.177.194:2049
20161003 22:19:25 I UDPv4 link local: [undef]
20161003 22:19:25 I UDPv4 link remote: [AF_INET]67.228.177.194:2049
20161003 22:20:25 I [UNDEF] Inactivity timeout (--ping-restart) restarting
20161003 22:20:25 I SIGUSR1[soft ping-restart] received process restarting
20161003 22:20:25 Restart pause 2 second(s)
20161003 22:20:27 W WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
20161003 22:20:27 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161003 22:20:27 Socket Buffers: R=[180224->180224] S=[180224->180224]
20161003 22:20:27 I TCP/UDP: Preserving recently used remote address: [AF_INET]67.228.177.194:2049
20161003 22:20:27 I UDPv4 link local: [undef]
20161003 22:20:27 I UDPv4 link remote: [AF_INET]67.228.177.194:2049
20161003 22:21:27 I [UNDEF] Inactivity timeout (--ping-restart) restarting
20161003 22:21:27 I SIGUSR1[soft ping-restart] received process restarting
20161003 22:21:27 Restart pause 2 second(s)
20161003 22:21:29 W WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
20161003 22:21:29 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161003 22:21:29 Socket Buffers: R=[180224->180224] S=[180224->180224]
20161003 22:21:29 I TCP/UDP: Preserving recently used remote address: [AF_INET]67.228.177.194:2049
20161003 22:21:29 I UDPv4 link local: [undef]
20161003 22:21:29 I UDPv4 link remote: [AF_INET]67.228.177.194:2049
20161003 22:22:29 I [UNDEF] Inactivity timeout (--ping-restart) restarting
20161003 22:22:29 I SIGUSR1[soft ping-restart] received process restarting
20161003 22:22:29 Restart pause 2 second(s)
20161003 22:22:31 W WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
20161003 22:22:31 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161003 22:22:31 Socket Buffers: R=[180224->180224] S=[180224->180224]
20161003 22:22:31 I TCP/UDP: Preserving recently used remote address: [AF_INET]67.228.177.194:2049
20161003 22:22:31 I UDPv4 link local: [undef]
20161003 22:22:31 I UDPv4 link remote: [AF_INET]67.228.177.194:2049
20161003 22:23:32 I [UNDEF] Inactivity timeout (--ping-restart) restarting
20161003 22:23:32 I SIGUSR1[soft ping-restart] received process restarting
20161003 22:23:32 Restart pause 2 second(s)
20161003 22:23:34 W WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
20161003 22:23:34 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161003 22:23:34 Socket Buffers: R=[180224->180224] S=[180224->180224]
20161003 22:23:34 I TCP/UDP: Preserving recently used remote address: [AF_INET]67.228.177.194:2049
20161003 22:23:34 I UDPv4 link local: [undef]
20161003 22:23:34 I UDPv4 link remote: [AF_INET]67.228.177.194:2049
20161003 22:24:34 I [UNDEF] Inactivity timeout (--ping-restart) restarting
20161003 22:24:34 I SIGUSR1[soft ping-restart] received process restarting
20161003 22:24:34 Restart pause 2 second(s)
20161003 22:24:36 W WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
20161003 22:24:36 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161003 22:24:36 Socket Buffers: R=[180224->180224] S=[180224->180224]
20161003 22:24:36 I TCP/UDP: Preserving recently used remote address: [AF_INET]67.228.177.194:2049
20161003 22:24:36 I UDPv4 link local: [undef]
20161003 22:24:36 I UDPv4 link remote: [AF_INET]67.228.177.194:2049
20161003 22:25:36 I [UNDEF] Inactivity timeout (--ping-restart) restarting
20161003 22:25:36 I SIGUSR1[soft ping-restart] received process restarting
20161003 22:25:36 Restart pause 2 second(s)
20161003 22:25:38 W WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
20161003 22:25:38 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161003 22:25:38 Socket Buffers: R=[180224->180224] S=[180224->180224]
20161003 22:25:38 I TCP/UDP: Preserving recently used remote address: [AF_INET]67.228.177.194:2049
20161003 22:25:38 I UDPv4 link local: [undef]
20161003 22:25:38 I UDPv4 link remote: [AF_INET]67.228.177.194:2049
20161003 22:26:38 I [UNDEF] Inactivity timeout (--ping-restart) restarting
20161003 22:26:38 I SIGUSR1[soft ping-restart] received process restarting
20161003 22:26:38 Restart pause 2 second(s)
20161003 22:26:40 W WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
20161003 22:26:40 W NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
20161003 22:26:40 Socket Buffers: R=[180224->180224] S=[180224->180224]
20161003 22:26:40 I TCP/UDP: Preserving recently used remote address: [AF_INET]67.228.177.194:2049
20161003 22:26:40 I UDPv4 link local: [undef]
20161003 22:26:40 I UDPv4 link remote: [AF_INET]67.228.177.194:2049
20161003 22:27:28 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:16
20161003 22:27:28 D MANAGEMENT: CMD 'state'
20161003 22:27:28 MANAGEMENT: Client disconnected
20161003 22:27:28 D MANAGEMENT: CMD 'status 2'
20161003 22:27:28 D MANAGEMENT: CMD 'log 500'
19700101 01:00:00
ca /tmp/openvpncl/ca.crt management 127.0.0.1 16 management-log-cache 100 verb 3 mute 3 syslog writepid /var/run/openvpncl.pid client resolv-retry infinite nobind persist-key persist-tun script-security 2 dev tun1 proto udp cipher aes-256-cbc auth sha256 auth-user-pass /tmp/openvpncl/credentials remote US-TX1.GW.IVPN.NET 2049 comp-lzo yes tun-mtu 1500 mtu-disc yes fast-io tun-ipv6 tls-auth /tmp/openvpncl/ta.key 1 tls-client tls-cipher TLS-RSA-WITH-AES-256-CBC-SHA resolv-retry infinite keepalive 10 60 nobind persist-key persist-tun persist-remote-ip verb 3
I am using the same router and the same VPN setup and it works fine for me. Only issue is occasional DNS failures, which I'm looking into now, but generally works fine. I'd go over the instructions again with a fine tooth comb - or maybe include screenshots of the setup (blanking out personal info, of course).
Well, sure enough - this stopped working last night. Going to battle with this again tonight, but it's worth noting that this failure happened after I upgraded to the latest Kong version from September. Previously had been using the July version.
I also use an R6400 with iVPN. My vpn is is working as of this post. So I dont think the issue is from a bug in the firmware.
