New R7000 nighthawk, which Tomato version is stable
3 posts / 0 new
getseman
Need to installed VPN, see different versions, which one is the one you guys recommend?
ALso if you can point me out to any instructions,it will be weel appreciated.
mlord
I think Shibby himself uses
I think Shibby himself uses an R7000, so one might expect his Tomato version to work reasonably well.  Also, any fixes from Shibby end up in Toastman's builds (and vice-versa), so those should be okay too.  But hopefully people who actually have R7000's will post which Tomato they use here.
microchip
Shibby used to use the R7000
Shibby used to use the R7000 as his main one but moved on to an AC3200 from ASUS. I run latest Shibby 138 AIO without a single glitch so it's been very stable for me
