R8000 on Tomato by Shibby 138 AIO
3 posts / 0 new
nofearjohn
Have always been using Tomato Shibby without too much on detail setting for previous ASUS routers.
First time changing to Netgear and some findings below would like to seek advice.
Some setup reference:
  • 5G both same SSID
  • wireless network mode: auto
  • channel width: 80 MHz
  • sideband: upper
questions:
  1. seems cannot choose network mode as ac only for both 5G?
  2. there's no difference in changing antenna transmit power? signal strength seems the same when change from default 40 to 70.
  3. need some advice on cifs mounting, upon setup only showing "mounting...", checked log always show error code -127. trying to save log into NAS.
fiacions123
Fifa 17 Coins It happens all
Fifa 17 Coins It happens all over the world, and in many cases the players are ultimately better off for it.But to then ignore the club that put them in that position in the first place is a grave disservice to a high end youth soccer production system we have tried and failed to produce in this country. The marginalization of the youth clubs identifying and developing these Fifa Coins players to put them in position for bigger things is the ultimate problem with our system. We don't value youth producers enough.
Roy2001
Shibby has very weak wifi
Shibby has very weak wifi signal compare to stock/dd-wrt.
