Hello
If so, how to do it?
Luki:
There is a theme
http://myopenrouter.com/forum/r7500v1-and-lte-modem
better to write there. I did not try to do the same for R7800 yet. While only for R7500v1
Hello Voxel
Thank you for your hard work.
Is there a chance to add an OpenVPN CLIENT (not the SERVER as it is in the original firmware)
I would like to use it with transmission BT...
thank you for your answer.
Hello Nilugeator,
OpenVPN is in FW, so it is possible to use it as a server or as a client too. But w/o WebGUI, manual configuration (config file) from console. Using OpenVPN from FW or from Entware-NG.
thank you for your answer!
I will try to find a tutorial to do that
some other questions :
1) Do you think that you will one day or another add webgui to openvpn? (lol) :)
2) With custom firmware like ddwrt or tomato, I used a script to set my VPN and exceptions (this computer goes through VPN, this one wont, etc..) I put this script inside the firewall script admin of the gui... Can I do the same with your firmware? (I didnt find some kind of "boot at startup script " section)
thanks in advance
Didnt find how to configure my openvpn client ...
I used airvpn provider
I have thoses files to use:
servername_UDP-443.openvpn
ca.crt
ta.key
user.crt
user.key
I read your "readme" file, I only had to put thoses files in /root/openvpn directory. ?
I should do something wrong, because it apparently cant connect to the vpn server of airvpn
My "readme" is related to use OpenVPN server. Controlled by WebGUI. You have to start your own client from console. Please send me your servername_UDP-443.openvpn if you do not know how to do that. Maybe in P.M. I'll iform you how to run client. Initially in manual mode, then you can use your own script in /etc/init.d/ directory.
Hi all,
I publish new version of custom firmware: 1.0.2.10SF.
The link is https://yadi.sk/d/Xmdn5x9Cw7fA5
What’s new/changed (vs 1.02.07SF):
a. Now the following algorithms are available, user can select: westwood+ reno cubic vegas yeah Illinois
b. Default algorithm is weswood+.
To use it you should attach modem to USB port. If no LTE modem is attached, router will operate as usual.
Great job Voxel. Thanks a lot :)
I publish new version of Entware compiled with optimization for use with IPQ806x CPU (optimization for Cortex-A15). This version is named by authors as Entware-3x, i.e. Entware for devices with version of kernel 3.x.
Main differences (vs Entware-ng):
Additional difference this version vs version I published last time (Entware-ng)
Difference my version vs official version
The links are:
https://yadi.sk/d/YROkl3T5xeCpR initial minimal set of preinstalled packages
https://yadi.sk/d/DTr4u2IRxe8AF full set of packages
Installation is similar to installation of Entware-ng.
I publish new version of custom firmware: 1.0.2.12SF.
The link is: https://yadi.sk/d/omigvS9qxjMTM
Changes (vs 1.0.2.10SF):
Thx for spooky build :)
I publish new version of custom firmware: 1.0.2.13SF.
Not so much time since 1.0.2.12SF release but Netgear released new stock FW.
The link is https://yadi.sk/d/53fQQWr6ybQF9
Changes (vs 1.0.2.12SF):
kmod-uvc-video_3.4.103-1_ipq806x.ipk
libwebcam_0.2.5_ipq806x.ipk
mjpg-streamer_r182-8_ipq806x.ipk
uvcdynctrl_0.2.5_ipq806x.ipk
/bin/opkg install kmod-uvc-video_3.4.103-1_ipq806x.ipk
/bin/opkg install mjpg-streamer_r182-8_ipq806x.ipk
/etc/init.d/mjpeg-streamer enable
andlibwebcam_0.2.5_ipq806x.ipk
are needed to install uvcdynctrl (camera control tools) if you need to change default camera controls such as focus, exposure, white balance temperature etc. Install first libwebcam then uvcdynctrl.Fantastic! I was just going to ask you about your new custom firmware based on the latest official. Thx and I'm glad that you can post again :)
Thanks for thanks ;-)
Yes, I warn everybody that I am often not able to post anything here, in this forum. Today and yesterday - exeptions.
Please for all your electronic/electrical appliances as well as manuals on how to install as well as repair such appliances, you can visit this page >>>http://www.win-source.net .
Hi guys, I'm struggling with the SSH authentication for some hours now. I can't get it to work.
Formated a USB-Key with ext2 with the command 'mkfs.ext2 /dev/sdb1'.
Generated a keypair with "ssh-keygen" and added the one in id_rsa.pub to 'authorized_keys' after unpacking setssh.tar on the root folder of the stick.
Checked if 'autorun/scripts/post-mount.sh' is set executable (+x).
Plugged the stick into USB1 on the Nighthawk and wait some minutes, tried to ssh to the router with result 'Permission denied (publickey).'.
Rebooted the router and tried again to ssh to the router with the same result.
I've also tried 3 different USB-sticks. Looks like the autorun script is not executed?
I'm using the last version you posted some days ago.
streilu:
https://yadi.sk/i/TZ9VR_ygyxQQZ
It is what to paste into authorized_keys, not id_rsa.pub.
Sorry, ignore this. I was not attentive.
You have to check by telnet (http://routerlogin.net/debug.htm) that /root/.ssh exists and there is proper authorized_keys there.
I got it now, the problem was that there was an empty authorized_keys file.
Modified the post-mount.sh to first delete this file and then to copy the right one.
Thanks anyway, great work from you!
Another question, is it possible to change the openVPN config to give the clients static IP addresses?
I corrected script and upgraded setssh.tar to avoid such problems in the future.
Regarding OpenVPN: you can control server config creration according to your taste modifying the file /etc/init.d/openvpn. Seek the lines:
Thanks, will give it a try to change the configs this evening.
What happens if I reconfigure it with the webinterface? Are these just the templates used by web-if?
Another problem: Does anyone else have problems with accessing LAN-clients (smb, rdp, ssh, ...) from WLAN-clients? Nothing working here except of pinging them. I don't know if that is related to your firmware or even to the original firmware. Maybe you can investigate that bug?
BR Luke
This script is used by Web-GUI.
I am sorry, but I do not have such problems. I often use my notebook (Wi-Fi) to enter to my Debian server (LAN, cable connection) by ssh, ftp, samba and http proxy. Last time yesterday.
It's not helpful, but I don't have such problem either. Are you using firewall?
No, I'm not using any firewall on any of my devices.
Accessing LAN devices is not possible from any wireless device (laptop, smartphone, tablet).
I think it may has something to do with VLAN on the WAN interface.
Hi Voxel.
Great job!
A perfect example, how to make the maximum of this powerful device.
And thank you very much for your help in PM)
Vladlenas:
You are welcome. But your PM is full now. I cannot write you in PM. You have to clean messages in PM
Does this have any advanced qos settings? Bascially like the sqm from openwrt?
QoS is the same like in stock FW.
