R8000 - DDNS - Firewall Blocking Traffic
2 posts / 0 new
JohnoB
JohnoB's picture
Upgraded my R8000 from stock firmware to DD-WRT "Kong Mod" for NETGEAR R8000 2016-11-10 and found that everythig is great  except for DDNS.
I am and have previously used No-IP.com with no issues.   I can see from the status window that the alias has been updated successfully and verified this within No_IP.com site.
The issue that I am experiencing is that I can remotely connect to and administer the router when the Firewall is turned off.  When the firewall is on the incomming connection attempt is dropped.   I can see this from the logs.
I have everthing unchecked on the firewall page except for Block Anonymous WAN Requests (ping).
I would really appreciate some assistance to get this working when the firewall is active.
Regards
John.
JohnoB
JohnoB's picture
Ok - fixed my own poblem
Ok - fixed my own poblem after sleeping on  it.
Issue was that I didnt add the port number to the address.   Ie: - for example:  http://abc.def.net did not work.   ttp://abc.def.net:8080 worked.
Hope this helps others in the future.
Regards
John.
