Successfull install of dd-wrt Kong-Mod for R6250
9 posts / 0 new
rsasusaa
rsasusaa's picture
I'm the happy owner of a R6250 and just installed the Kong Mod (from: https://www.myopenrouter.com/download/dd-wrt-kong-mod-netgear-r6250-2016...) on my router.
Firstly, I seeked help in forums (here: http://www.dd-wrt.com/phpBB2/viewtopic.php?t=51486)
And then I used the old installation guide for my R6300, because I'm a newb  (here: https://www.dd-wrt.com/wiki/index.php/Netgear_R6300#Guides) and it's years in between flashing my fw. Though I made a 30-30-30 reset as the first reset, instead of the 'regular' factory reset.
Everything seems in order, though the Netgear logo doesn't light - which is okay, then I save some milli-amps when it's on ;-)
Now it's time to see if it behaves properly. Mad props for all people working on this and discussing this on these fora - then it's actually an option to use google and find proper instructions! ;-)
Cheers Rasmus
Mastec
Mastec's picture
You will love Kong on your
You will love Kong on your R6250.  I've been using it for months.  Zero signal drops and zero slowdowns.
daviziko
daviziko's picture
Does the 5GHz WiFi work?
Mastec
Mastec's picture
Yes it does, strong signal
Yes it does, strong signal too.  Neighbor across the street and another 2 houses away can pick up my wifi.
vito333
vito333's picture
Please, tell me, has dd-wrt
Please, tell me, has dd-wrt Kong Mod HDD spindown option?
vito333
vito333's picture
stock firmware has not, my
stock firmware has not, my HDD work permanently
Jacob Witt
Jacob Witt's picture
Anyone know how to turn on
Anyone know how to turn on the Netgear Logo? Just wondering, I know you can turn it on using serial commands from telnet but thats only temp until it reboots.
Looking for a more perminant solution.
Mastec
Mastec's picture
I asked Kong this question
I asked Kong this very question last year.  Here is his reply.....
Hi Mastec,
I know the lights are not working, unfortunately I did the port
without a router and I know it is not possible to control them via gpio
commands, in such a case there is a problem with gpio init which we can
fix if we have the hardware in order to test a few register hacks.
hspot
hspot's picture
Works PERFECT!
Works PERFECT!
System
Router Name
DD-WRT
Router Model
Netgear R6250
Firmware Version
DD-WRT v3.0-r32170M kongac (06/11/17)
Kernel Version
Linux 4.4.70 #340 SMP Sun Jun 11 12:38:55 CEST 2017 armv7l
MAC Address
2C:30:33:C9:D5:8B
Hostname
R6250
WAN Domain Name
LAN Domain Name
Current Time
Sun, 03 Sep 2017 11:56:16
Uptime
3:54
CPU
CPU Model
Broadcom BCM4708
CPU Cores
CPU Clock
800 MHz
Load Average
0%
0.00, 0.03, 0.00
CPU Temperature
CPU 68.0 °C / WL0 48.9 °C / WL1 49.0 °C
Memory
Total Available
97%
254596 kB / 262144 kB
Free
85%
215304 kB / 254596 kB
Used
15%
39292 kB / 254596 kB
Buffers
12%
4520 kB / 39292 kB
Cached
32%
12632 kB / 39292 kB
Active
30%
11844 kB / 39292 kB
Inactive
18%
7112 kB / 39292 kB
Space Usage
NVRAM
36 KB / 64 KB
CIFS
(Not mounted)
JFFS2
(Not mounted)
Network
IP Filter Maximum Ports
32768
Active IP Connections
1%
181
