I am new here. I tried to flash the dd-wrt Kong Firmware from this Link https://www.myopenrouter.com/download/dd-wrt-kong-mod-netgear-r6250-2016-11-10.
I downloaded the zip file, exctracted the chk file and followed the guides I found here https://www.myopenrouter.com/forum/successfull-install-dd-wrt-kong-mod-r6250.
I made a 30-30-30 reset, I am hard wired, no other devices were plugged in (I really followed the instructions!) but it always ends with a bootloop. After returning to stock firmware over serial I tried an older Kong Firmware but the result was the same.
After a 30-30-30 reset i cancelled the boot process, activated tftpd and transfered the firmware with tftp. This way ended with a bootloop, too.
I have no idea what I have done wrong but it seems that I am the first here with this problem. Because of the possibility to go back to stock firmware over serial I am not affraid to try some suggestions.
I copied this from minicom. I marked some lines that could be interesting. Thank you for reading!
Uncompressing Linux... done, booting the kernel.
** 16 printk messages dropped ** PERCPU: Embedded 11 pages/cpu @86dd4000 s129406
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65280
Kernel command line: console=ttyS0,115200 panic=10 root=/dev/mtdblock3 earlyprih
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 254176K/262144K available (3414K kernel code, 195K rwdata, 1204K rodata)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0x88800000 - 0xff800000 (1904 MB)
lowmem : 0x80000000 - 0x88000000 ( 128 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.text : 0x80008000 - 0x8048ae3c (4620 kB)
.init : 0x8048b000 - 0x804e0000 ( 340 kB)
.data : 0x804e0000 - 0x80510ef0 ( 196 kB)
.bss : 0x80513000 - 0x805881e4 ( 469 kB)
Hierarchical RCU implementation.
CONFIG_RCU_FANOUT set to non-default value of 2
Build-time adjustment of leaf fanout to 2.
NR_IRQS:256
MPCORE GIC init
soc_dmu_init
add clk lookups
MPCORE Global Timer Clock 400000000Hz on IRQ 27
sched_clock: 32 bits at 400MHz, resolution 2ns, wraps every 5368709118ns
clocksource: mpcore_gtimer: mask: 0xffffffffffffffff max_cycles: 0x5c4093a7d1, s
register local timer
smp_twd: clock not found -2
Calibrating local timer... 399.68MHz.
Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
2 cores has been found
Setting up static identity map for 0x85e0 - 0x8614
L2C: platform provided aux values permit register corruption.
L2C: DT/platform modifies aux control register: 0x0a130000 -> 0x7a530000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 256 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x4e530001
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (3188.32 BogoMIPS).
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 191s
DMA: preallocated 256 KiB pool for atomic coherent allocations
coherence_win_size = 10000000
coherence_flag = FFFFFFF8
ddr_phys_offset_va =FFFFFFFF
ddr_phys_offset2_va =A8000000
Found a Samsung NAND flash:
Total size: 128MB
Block size: 128KB
Page Size: 2048B
OOB Size: 64B
Sector size: 512B
Spare size: 16B
ECC level: 8 (8-bit)
Device ID: 0xec 0xf1 0x 0 0x95 0x40 0xec
found nand nvram at 80000
CCA UART Clock Config: Sel=1 Ovr=1 Div=48
CCA UART Clock rate 100000000Hz CCB UART Clock rate 100000000Hz
clocksource: Switched to clocksource mpcore_gtimer
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
init gpio code
Netgear AC1450/R6250/R6300v2/EX6200 init
PCI: no core
PCI: no core
PCI: scanning bus 0
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io 0x0000-0xffffffff]
pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
pci_bus 0000:00: root bus resource [bus 00-ff]
pci 0000:00:0f.0: [Firmware Bug]: reg 0X10: invalid BAR (can't size)
PCI: Fixing up bus 0 domain 0
PCIE1 link=1
PCI host bridge to bus 0001:00
pci_bus 0001:00: root bus resource [mem 0x08000000-0x0fffffff]
pci_bus 0001:00: No busn resource found for root bus, will use [bus 00-ff]
PCI: Fixing up bus 0 domain 1
PCI: bus0: Fast back to back transfers disabled
PCI: Fixing up bus 1 domain 1
PCI: bus1: Fast back to back transfers disabled
pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
pci 0001:00:00.0: PCI bridge to [bus 01]
pci 0001:00:00.0: bridge window [mem 0x08000000-0x080fffff]
PCIE2 link=1
PCIE2 switching to GEN2
PCIE2 link=1
PCI host bridge to bus 0002:00
pci_bus 0002:00: root bus resource [mem 0x40000000-0x47ffffff]
pci_bus 0002:00: No busn resource found for root bus, will use [bus 00-ff]
PCI: Fixing up bus 0 domain 2
pci 0002:01:00.0: Max Payload Size set to 512 (was 128, max 512)
PCI: Fixing up bus 1 domain 2
pci 0002:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
pci 0002:01:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
pci 0002:00:00.0: PCI bridge to [bus 01]
pci 0002:00:00.0: bridge window [mem 0x40000000-0x400fffff]
PCIE3 link=0
futex hash table entries: 512 (order: 3, 32768 bytes)
io scheduler noop registered (default)
io scheduler cfq registered
serial8250_init
Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
console [ttyS0] disabled
serial8250.0: ttyS0 at MMIO 0x18000300 (irq = 117, base_baud = 6250000) is a 160
console [ttyS0] enabled
serial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117, base_baud = 6250000) is a 160
brd: module loaded
loop: module loaded
Boot partition size = 524288(0x80000)
lookup_nflash_rootfs_offset: offset = 0x380000 size = 0x1c80000, 0x20000
found TRX Header on nflash!
nflash: squash filesystem with lzma found at block 42
0x000000380000-0x000002000000 : "linux"
0x000000540000-0x000002000000 : "rootfs"
0x000000200000-0x000000220000 : "board_data"
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
PPP BSD Compression module registered
PPP Deflate Compression module registered
GACT probability NOT on
Mirror/redirect action on
Simple TC action Loaded
netem: version 1.3
u32 classifier
Performance counters on
input device check on
Actions configured
nf_conntrack version 0.5.0 (3971 buckets, 15884 max)
nf_conntrack_rtsp v0.7 loading
ip_set: protocol 6
gre: GRE over IPv4 demultiplexor driver
nf_nat_rtsp v0.7 loading
bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update yo.
Bridge firewalling registered
8021q: 802.1Q VLAN Support v1.8
Registering SWP/SWPB emulation handler
max nvram space = 131072
read 65536 bytes to offset 0
Key type encrypted registered
Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2
nand: device found, Manufacturer ID: 0xec, Chip ID: 0xf1
nand: Samsung NAND 128MiB 3,3V 8-bit
nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 343
(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0
Bad eraseblock 40 at 0x000000500000
Bad eraseblock 225 at 0x000001c20000
Options: CACHEPRG,NO_SUBPAGE_WRITE,
0x000002000000-0x000008000000 : "ddwrt"
VFS: Cannot open root device "mtdblock3" or unknown-block(31,3): error -19
Please append a correct "root=" boot option; here are the available partitions:
0100 4096 ram0 (driver?)
0101 4096 ram1 (driver?)
0102 4096 ram2 (driver?)
0103 4096 ram3 (driver?)
0104 4096 ram4 (driver?)
0105 4096 ram5 (driver?)
0106 4096 ram6 (driver?)
0107 4096 ram7 (driver?)
0108 4096 ram8 (driver?)
0109 4096 ram9 (driver?)
010a 4096 ram10 (driver?)
010b 4096 ram11 (driver?)
010c 4096 ram12 (driver?)
010d 4096 ram13 (driver?)
010e 4096 ram14 (driver?)
010f 4096 ram15 (driver?)
1f00 512 mtdblock0 (driver?)
1f01 1536 mtdblock1 (driver?)
1f02 29184 mtdblock2 (driver?)
1f03 27392 mtdblock3 (driver?)
1f04 128 mtdblock4 (driver?)
1f05 98304 mtdblock5 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
CPU1: stopping
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.4.30 #142
Hardware name: Northstar Prototype
Backtrace:
[<8001b0c8>] (dump_backtrace) from [<8001b29c>] (show_stack+0x18/0x1c)
r7:87853f58 r6:60000193 r5:00000000 r4:80500edc
[<8001b284>] (show_stack) from [<8015e560>] (dump_stack+0x8c/0xa0)
[<8015e4d4>] (dump_stack) from [<8001ce7c>] (handle_IPI+0x110/0x1a8)
r7:87853f58 r6:00000001 r5:00000000 r4:805131a0
[<8001cd6c>] (handle_IPI) from [<80009394>] (gic_handle_irq+0x78/0x7c)
r7:b0100100 r6:87853f58 r5:b010010c r4:804efb14
[<8000931c>] (gic_handle_irq) from [<80009e80>] (__irq_svc+0x40/0x54)
Exception stack(0x87853f58 to 0x87853fa0)
3f40: 86ddf240 00000000
3f60: 00000848 8000a960 87852000 804ef8e0 804250cc 804dc220 87853fc8 413fc090
3f80: 00000000 87853fb4 87853fb8 87853fa8 80018d28 80018d2c 60000013 ffffffff
r9:413fc090 r8:87853fc8 r7:87853f8c r6:ffffffff r5:60000013 r4:80018d2c
[<80018cf0>] (arch_cpu_idle) from [<80069d10>] (default_idle_call+0x30/0x34)
[<80069ce0>] (default_idle_call) from [<80069e1c>] (cpu_startup_entry+0x108/0x1)
[<80069d14>] (cpu_startup_entry) from [<8001cb34>] (secondary_start_kernel+0x15)
r7:80513180 r4:804fd858
[<8001c9e4>] (secondary_start_kernel) from [<00009428>] (0x9428)
r5:00000055 r4:0782c06a
Rebooting in 10 seconds..
Assuming you are using Windows. What I do when I install is as follows....
Open a Command Prompt window and at the prompt enter "ping -t 192.168.1.1" without the quotes. This will let you know when your router is ready to use.
1) Open Netwrork and Sharing Center.
2) Click on Ethernet to open the Ethernet Statud box.
3) Click on Properties.
4) Click to highlight Internet Protocol Version 4 (TCP/IPv4)
5) Click on Properties to open a new box.
6) Click on "Use the following DNS server address:"
7) in IP address enter 192.168.1.5
8) in Subnet mask: enter 192.168.1.1
9) in Default gateway: enter 192.168.1.1
10) Click OK
11) Click OK
12) Click Close
13) Open a browser window and open 192.168.1.1
14) If Netgear Genie opens reset everything to default
15) Click on the link to upgrade the firmware and find the KONG file on your computer
16) Click Upgrade
17) Keep an eye on the Command Prompt window. You will see the router stop talking to your computer. If there is no ping DO NOT click on Continue. Wait until you see "Reply from 192.168.1.1: bytes=32 time<1ms TTL=64". This will tell you that your router is back on line and ready to go.
I hope this helps you. Good Luck.
OH YEAH! Don't forget to repeat steps 2 thru 5 and click on Obtain an IP address automatically then click OK. OK again. Finally Close.
Just reread what I poste3d and realized I made an error.
8) in Subnet mask: enter 192.168.1.1 should actually be 255.255.255.0
Sorry
thank you for helping me. I am on Ubuntu not on Windows but it doesn't matter because i do not use dhcp so I always have a static IP (192.168.1.100).
That is not the problem. After restoring system defaults I choose the dd-wrt.K3_R6250.chk and upload it. Because I am connected through serial port I can see via minicom that the file is uploaded and flashed successfully. After an automatic rebbot I stuck in a bootloop as described. :(
So for me your first 12 steps are not necessary (getting static IP in the router network) and the other steps are in logical order. I have no idea what I am doing wrong...
OK I figured out the problem. After searching for hours on different sites someone has the same problem. The good news is I've done nothing wrong. Bad news is there is no tested solution yet. As you can see in the log in the first post I have some bad blocks on the Samsung chip. The bad blocks cannot be rewritten so dd-wrt is not able to flash the rootfs partition correctly. That causes the kernel panic and the bootloop.
I need to write the partition to another adress on the NAND. but I do not know how. If I have more time I will try to set a new offset, hoping the flash progress will continue properly. If I succeed I will post my solution...
It has also been reported by someone on the dd-wrt forums that downgrading to an older kong release works. Then you can upgrade from there.
Kongs command line method is the suggested method.
It works great.
