DD -WRT Kong Mod on R7000-100PES
10 posts / 0 new
azeotropy
azeotropy's picture
I live in France and I'll soon buy a router to put DD WRT on it. However I have 3 questions :
-> I want to buy the R7000-100PES (the only model available in France), is the -100PES okay with Kong and 5ghz ? (LINK HERE TO AMAZON PAGE)
-> Is there a simple guide (updated one) to install the router, because the only tutorials I can find are from 2014 and the router might have changed since.
-> Is there a risk to brick it definitively or i there always a way to unbrick it (link TFTP) when installing king.
Thanks for taking the time to answer me :)
Azertro-
RogerB
RogerB's picture
I think I just sent you a
I think I just sent you a message. I will repost here in case someone else has input.
I was attempting to load the dd-wrt firmware on my R7000 router lastnight.
I looked at the tutorial located at http://www.tweaking4all.com/hardware/netgear-r7000-dd-wrt/
It indicates that you first load an initial firmware .chk file, then you load a Kong mod.
Since that was from 2014, it may be an old method. Maybe now you just do the Kong file, such as dd-wrt.K3_R7000.chk which came out quite recently.
Let me know if you know otherwise.
HTH,
Roger
mesteele101
mesteele101's picture
This link should get you
This link should get you going...
mesteele101
I hate using these forums...
Try this link...
tunafish
tunafish's picture
I have the same question, i
I have the same question, i flashed my Netgear R7000 with the file dd-wrt.K3_R7000.chk about a week ago and everything has been fine but my question is do Istill need to flash dd-wrt.v24-K3_AC_ARM_STD.bin they both have the same modified date 2017-01-18.
RogerB
RogerB's picture
That is the link which I
That is the link which I provided above, which is from 2014 and has steps which we are trying to determine if deprecated.
RogerB
RogerB's picture
Where did you find dd-wrt.v24
Where did you find dd-wrt.v24-K3_AC_ARM_STD.bin ?
Does it have that modified date because you downloaded it on 2017-01-18? I am betting so.
When I look at this site: http://www.desipro.de/ddwrt/K3-AC-Arm/    all the .bin files seem to have router models in the file name. I don't see any such files for an R7000 router, just the .chk file.
azeotropy
azeotropy's picture
Thanks for all you anwser, my
Thanks for all you answer, my main question was about R7000-100PES, is it compatible ?
Thanks !
azeotropy
azeotropy's picture
Here's the link http://www
azeotropy
azeotropy's picture
Just receievd a mail from
Just receievd a mail from kong himself :
"Hello, in France the model R7000-100PES is sold. Is it compatible with your dd-wrt ?"
He answered "Yes it is compatible. Cheers, Kong"
So the R7000-100PES is compatible with Kong DD-WRT :)
