Try to install Private Internet Access VPN from Netgear R8000 Router.
I managed succesfully flash my router(using DD-WRT "Kong Mod" for NETGEAR R8000 2016-11-10)
I select TigerVpn, because there is ready startUp script for DD-wrt, https://help.tigervpn.com/support/solutions/articles/1000203620-dd-wrt-
Breaf moment after script setup, everything works fine. But then vpn just disapear and even router boot wount restart vpn. Only working method is reset factory defaults and re setup startup script?
Any suggestion what I should try?
Are you sure you want to run a VPN? As of 12/1/16, the FBI is authorized by Congress to go after anyone who uses a VPN (or any other means) to anonymize an IP. Not sure how a corporate VPN would be distiguished from, say, Opera VPN, assuming no anonymization is intended.
Yeah, like it took a law for them to do it in the past. I guess they need to justify the asses in seats. Long list be freedom.
