r7000 dd-wrt and tomato and locked out??
4 posts / 0 new
keef
Hello. I was playing with Kong dd-wrt and disappointed in the G speeds, I remember  them much faster under Tomato. My plan was to flash OFW (done) then flash Shibby. Well OFW flashed fine however I am locked out. The usual admin/password does not work. I tried a pin-hole rest but no luck.
How do I get past this?
thanks, Bj
keef
Well now I dun it. After
Well now I dun it. After flashing  OFW I flashed Shibby. It comes up fine however only the power light and port 1 link light are on. Pin hole reset does nothing. I pull the power for a while also does nothing. Telnet is unavailable
Is this bricked at some level? I can still get into Shibby Tomato so there is some life there.
thanks, Bj
keef
Well correction - SHibby does
Well correction - SHibby does not come up anymore. What a mess.
thanks for any help guys, Bj
gtheuws
well I have a similar problem
well I have a similar problem. I flashed my netgear R7000 with Tomato. Now I would like to flash to OFW but keep on getting Bad-Trx-header. I would appreciate some help on this. Or please point me into the right direction.
Where do I download the OFW and how can I flash then into the netgear device.
