Wireless Physical Interface wl2 - accepting only WEP no matter what other security is used. All other (wl0 and wl1) is working with WPA2.
Firmware: DD-WRT v3.0-r30910M kongac (12/02/16)
Only way to remove WEP is to disable wl2.
Is this a bug or is it me missing something?
/Micke
I'm having the exact same problem, has anyone else heard of this happening before?
I'm not even able to connect to it. Does it allow you to connect to wl2 connection?
Having the same issue with WEP coming up even though WPA2 is selected. Haven't figured a way around it yet.
