Hi there,
I recently switched to R9000 and flashed openwrt. It works like a charm, many thanks for providing the image.
I have a question though:
I am missing a package repository for this. Can I use packages for any of the other openwrt architectures?
If not, is the source available / is there some information on how to build the missing packages?
Many thanks,
Tobias
do you know if it is possible to use the SFP port as a WAN port with the openwrt firmware?
thanks,
Francois
Hello, I am interested in the NETGEAR Nighthawk X10 R9000. Works with the DD-WRT firmware of the 10G Lan SFP + port still. That would be the buying decision for me. Best regards Mario
I have the Netgear X10 R9000 an just Installed DD-WRT what are the best settings to set like in wireles Etc..Looked online cant really find anything...
