OpenWRT Wifi settings on R9000
4 posts / 0 new
psychopomp1
psychopomp1's picture
I've managed to install OpenWrt (Barrier Breaker) fw on my R9000 and all is working well. However i cannot find anywhere where I can change the channel bandwidths (20/40/80mhz) for the 2.4ghz and 5ghz radios. Maybe its locked down?
Also would I be able to install the latest Openwrt built 15.05 (Chaos Calmer) on my R9000 or would i risk bricking it?
Cheers
Psycho
Peter Redmer
Peter Redmer's picture
I would wait until there's an
I would wait until there's an "official" R9000 release, otherwise there is likely a risk of bricking. I don't know for sure but I hope we'll see a Chaos Calmer release soon.
tobsch
tobsch's picture
You can still change wifi
You can still change wifi settings in /etc/config/wireless.
There are some tuning options available too, just google for em.
mgmihir44
mgmihir44's picture
I want to use 60GHz Wi-Fi of Nighthawk X10 R9000 and measure RSS. I need ssh access to the router to measure RSS
I would like to know if OpenWRT Firmware will support 60GHz?
Mihir
