UVC: There are some significant problems you can meet. Lack of necessary headers in kernel, etc. Because of relatively old version of kernel.
I'll try to build myself, you will test, OK? I am not sure in success...
Hi Voxel,
Thankyou so much. Just build it when you have spare time. I will test it afterwards...:)
Caspar
casparpoon:
https://yadi.sk/d/6E6mv0dP3ASeXA
ZIP with *.ko modules. To test you should load them from console, manually (by insmod). Order to load:
Please let me know results.
Hi Voxel,
Thankyou very much. The kernel modules work like a charm!
dmesg result:
usb 1-1: new high-speed USB device number 2 using xhci-hcd
usb 1-1: New USB device found, idVendor=0408, idProduct=2090
usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1: Product: Astro HD Camera
usb 1-1: Manufacturer: QCM
INFO008C: Add device intf cc126c00, dev cd559000
INFO0BF9: filter audio device
INFO008C: Add device intf cc127600, dev cd559000
INFO008C: Add device intf cc126a00, dev cd559000
INFO008C: Add device intf cc126000, dev cd559000
INFO008C: Add device intf cc127200, dev cd559000
Linux video capture interface: v2.00
uvcvideo: Found UVC 1.00 device Astro HD Camera (0408:2090)
uvcvideo: No streaming interface found for terminal 9.
input: Astro HD Camera as /devices/platform/ipq-dwc3.0/dwc3.0/xhci-hcd.0/usb1/1-1/1-1:1.0/input/input0
usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
Thanks again!
Caspar
You are welcome, glad it works.
I just updated my stock firmware to your version in hope of getting rid of the dreaded NAT Type: Unavailable on Xbox One. This issue is driving me crazy.
It usually goes away after a quick router reboot but it shouldn't be a problem in the first place. I tried Upnp, manually port forwarding, dmz...everything to no avail.
I know this isn't really your problem just venting at this router.
Anyway, I signed up to thank you and to tell you of this one issue currently:
I cannot update QOS database. Gives me Failed to download Detection Database. Please try again later message. This also happened with stock firmware but by pure luck it updated itself overnight. Should I be patient or any trick to this?
Regards.
I am fairly noob to this so hope there is an easy way to update QOS database. :(
You know, Netgear set the status "End-of-Life" for R7500v1. I.e. no updates anymore. So IMO it is a reason.
You can try again, I know that sometimes my R7800 also fails to check updates.
1. OpenSSL version is upgraded 1.0.2j->1.0.2k
2. OpenVPN version is upgraded 2.3.13->2.4.0.
3. ethtool version is upgraded 3.4.1->4.8.
4. e2fsprogs version is upgraded 1.43.1->1.43.3.
5. Changes in several scripts to use direct path to firmware /bin/opkg (to avoid conflicts with opkg from Entware).
6. dnscrypt-resolvers.csv is updated.
7. Toolchain: GCC compiler version is changed and its most recent OpenWRT & Debian patches are used.
8. Toolchain: yet two components are upgraded.
9. Host tools: three components are upgraded.
I kept trying for 2 days to update the QOS to no avail now. With your custom firmware, My Xbox One no longer gives me NAT Type Unavailable. Of course I cannot be 100% certain because it usually rears it's ugly head randomly. Knock on wood.
But now I only need to get this QOS sorted out. I will try your new firmware. Maybe it will go through with it.
If not, is there anything I can do to fix it? I am willing to be your guinea pig. I bought this cheap since it was on clearance but I sure didn't know I will get into this much trouble. Thankfully you are doing's god work so I really appreciate all the work you put into this.
Tried the new firmware. Still Failed to Download Detection Database. :(
Is there no way to integrate the QOS Database with the firmware?
Hi Voxel,
I was trying your git R7500 tree but it's dying on openssl no matter if 1.0.2k or 1.0.2j:
I'm using the toolchain from R7500-and_qtn_gpl_src_V1.0.0.94.zip .. do you know what might go wrong here?
Thomas
Roobaj:
I can continue in P.M.
reiffert:
Hints:
You should either:
1. Change compiler options adding "-march=armv7-a" (but not compatible with Cortex-A15 options)
or
2. Correct OpenSSL makefiles/configs using your patches
or (as I do in my git)
3. Use "compile.sh" and asm-openssl-1.0.2k.tar. Look into compile.sh script.
Sorry, I do not understand your quiestion.
Hi...
I would like to try installing your firmware on Linksys e8350, my only concern is if Quatenna firnware is compatible, do you have R7500v1 flash layout ?
Sorry, I haven't understood how to establish your insertion though I am not a noob! Whether it is enough to stitch via the interface of a router your insertion of R7500-V1.0.1.14SF.img and to make dumping of a router or it is necessary still that to do that?
It is enough to use WebGUI from your stock firmware to flash my build, the same as it would be a new stock firmware. And reset after this.
Hi Voxel. Thanks for the firmware. Bought this R7500 few days back. Even with great hardware, this device is poor. Espicially the wifi signal. My Tenda router with single antenna is giving better signal than this beast with 4 horns. Don't know why. And no proper custom firmware to customize my device. Thought I was doomed. I relaxed a bit after seeing your posts and how much you are active on this device.
Flashed your firmware, everything is working fine. Performance is good.
I observer few minor glitches in WebUI. In Attached Devices, if I enable Access Control, the table layout is broken. ( It was working fine in stock 1.0.0.94, I used this frequently).
Haven't tried SSH access yet, will try it to customize my router more.
I have a few requests,
1. Is there anyway to add Wifi repeater mode to this mode?
2. Is it possible to increase wifi singal?
Once again thanks for your hardwork and dedication.
xpress7:
1. Repeater: sorry, no. It is not included into stock firmware and too problematic to implement w/o access to full source codes. Some parts of Netgear GPL are closed.
2. Increase the TX power of signal. You know, in general I am against such stuffs. It is possible technically , but might violate the laws of your country, is bad for health etc. I would like to avoid my participation in this ;-) Try to contact robysax in P.M.
@Voxel With R7500-V1.0.1.14SF.img internet speed is limited to max ~165Mb/s and with original firmware 1.0.0.94 goes to full speed of 500Mb/s.
Can You try to fix that?
Thanks in advance
Nebojsa
[URL=http://www.speedtest.net/my-result/6115805786][IMG]http://www.speedtest.... with 1.0.0.94
[IMG]http://www.speedtest.net/my-result/6115053282[/IMG]
nesham:
Could you give me more info re: what connection did you test (wireless or cable) etc. Is it stable result, do you use the same host for testing?
BTW your images are not accessible.
I corrected him links
http://www.speedtest.net/result/6115805786.png
In addition, I can see that too does not work igmpproxy (IPoE)
Tested cable connection. Yes, stable result and same host in both tests.
It sounds strange for me: LAN provides 1000Mbit, but WAN not. Did you do full reset after flashing? Netgear's important notes to flash 1.0.0.94 over 1.0.0.82 was: obligatory reset because of changed drivers. I used 1.0.0.82 for my builds, so anyway, this reset. Also, 1.0.0.82 kernel version is 3.4.0, but 1.0.0.94 kernel version is 3.4.103.
Regarding fixing. Sorry:
1. I do not have such speed with my ISP.
2. I practically freeze suppot of R7500. I do not have R7500 anymore (I have changed it to R7800). Sorry.
Maximum what I can is renew some packages and ask somebody to test. So, VSG: igmpproxy - also I cannot trace and test.
In general, if really problems with WAN connection, then the reason should be in ethernet driver. But driver from 3.4.103 is not workable in 3.4.0.
WAN is not problem. In QoS Setup test gives 500/50Mb but over LAN maximum is 160/50. With 1.094 On both is 500/50.
