I am very new at this and am stuck trying to get my USB drive to be accessible through my network. I have USB Core, storage, and auto mount enabled and my 500GB drive formatted as EXT4 with just one partition. I enabled SAMBA and added my workgroup...added my share and gave it a name...no user/pass at this time...applied and saved all settings and I cant see in my netowrk! I have reflashed the firmware, set back to default settings,...re formatted the drive as EXT2, EXT3 and now EXT4....
What am I missing here?
I should also add that I have Kernell 4.4.43. I formatted back to ext 3 and rebooted again. Still no network access. This has to be something easy I am missing. Any help will be appreciated. Thanks
Have you turned on USB functionality? I don't believe this is on by default. Don't use it myself....
I did turn it on. I could never get it to work running dd-wrt. I loaded tomato and it worked first time.
