Cannot get back to Netgear firmware from Tomato
5 posts / 0 new
samfoley
samfoley's picture
I keep getting
/tmp/flashsCcGfD: Bad trx header
I have tried going straight to DD-WRT, but I get the same error.
process. DL firmare from Netgear, unzip.
Tomato, Admin/upgrade/select firmware from unzipped folder/Upgrade/Confirm?
Please advise
Sam
foil
foil's picture
Have you tried the
gennadiv
gennadiv's picture
PLEASE HELP!!!
PLEASE HELP!!!
I followed the instructions to install shibby tomato on R8000, however once I loaded the initial file - Router keep restarting!
I can ping to the router before its cycling the power, however cannot erase flash with TFTP2. Nothing helping - tried 30-30-30 and hitting buttons
I'm not a novice in this loading both tomato and dd-wrt for years
Even though i can ping 192.168.1.1 as my router - I cannot re-flash it with even stock firmware
Please help!
rcd
rcd's picture
This link is for R6400, not
This link is for R6400, not R7000.   Is there an equivalent to the "back to genie" flash file for R7000 ?
MaxSeven
MaxSeven's picture
The discussion is a little
The discussion is a little old but yeah, there is one:
http://tomato.groov.pl/download/K26ARM/Netgear%20R-series%20back%20to%20...
