Just got my new netgear nighthawk 6x
But the wifi signal wont connect with electronic devices. Seems like I cant go through the routerlogin.net setup. it keeps timing out.
My devices says its connected, but I dont have internet access.
What can I do?
I had the same problem, it does not make any sense what so ever. I had to use my MAC computer to complete the setup. The dumbest feature I have ever seen. I have issues with static IP assignment as well. DHCP works well. Connect by cable is your best option and DHCP. If you have a MAC that is even better. Get safar browser or the Netgear Genie App to assist in the process. Dumbest initial set up I have ever witnessed in my life. Hope you figured it out
