I'm running Kong's latest build (DD-WRT v3.0-r31870M (04/16/17)) on an R6700.
I would like to turn off all LED lights.
I've tried various commands I've found online for R7000, but none seem to work. Can someone more knowledgable than I give me an accurate copy/paste of the correct command lines to turn off all LEDs?
Thanks in advance.
[crickets]
Nevermind, I found a solution for R7000 that works for R6700 via the DD-WRT Forum:
https://dd-wrt.com/phpBB2/viewtopic.php?p=905942#905942
Great to hear that you have found solution of your problem, I have same problem and would like to follow your process.
