Where to get ddwrt-to-netgear-fw-R7800.bin? 403 error for www.desipro.de
9 posts / 0 new
teet
Hi there,
Anyone can point me where I can get ddwrt-to-netgear-fw-R7800.bin file? I got 403 forbidden while accessing http://www.desipro.de/ddwrt/K3-AC-IPQ806X/
Thanks in advance!
mrmidnight
Here ya go, direct link to
Dmitry Zhuravlev
Hello! tell me where to get
Hello! tell me where to get the firmware ddwrt-to-netgear-fw-R7800.bin ?  According to the links got 403 forbidden while accessing http://www.desipro.de/ddwrt/K3-AC-IPQ806X/.......If not hard reset on the mailbox [email protected] thanks in advance!!
Dmitry Zhuravlev
Здравствуйте! скажите мне , где взять прошивку  DDWRT к NetGear-Fw-R7800.bin?  По ссылкам получили 403 запрещено при доступе к HTTP: //www.desipro.de/ddwrt/K3-AC-IPQ806X / ....... Если не трудно сбросить на почтовый ящик [email protected] заранее спасибо! !
decalman
Where can I find ddwrt-to
Where can I find ddwrt-to-netgear-fw-R7800.bin the web page is not working
Thanks in advance
linch
https://mega.nz/#!M0pzFYrT
jandockx
I have just spend some hours
I have just spend some hours trying to locate the lost `ddwrt-to-netgear-fw-R7800.bin` file. To save other people the trouble:
https://www.dropbox.com/s/e2bqagpgkcm7pul/ddwrt-to-netgear-fw-R7800.bin?...
will be there for a few months or years …
Thatbloke
Thank you, jandockx.
Dick Darlington
THANK YOU!
THANK YOU!
