Hi guys,
I am new to this, and just flashed my X8 following th guides. That went fine, was not too difficult however, I am unable to connect using WPA2 AES on WI0 (5Gz) I am able to connect on 2.4 Gz with the same settings.
All Wifi network names are diffrent and all are setup using the same settings. I used the latest Kong file (3.21.17) when I flashed my router. I factory reset the router after flashing. Am I missing something here? How may I fix this. When I attempt to connect I get prompted to enter the password I enter it and it just prompts me again saying invalid password (I verified the password even changed it to ensure it was entered correctly). The network does connect without any security.
Thank you for your time and any suggestions you may have.
AL
Sorry for the post, I just noticed that I had both 5Ghz and 2.4Ghz selected in the basic configuration I changed it to be only 5 Ghz and now it seems to work fine. Just wanted to post that in the event someone else had the same issues.
