I have decided to upgrade my R7000's firmware but have found no matter what version of Kong's newer builds I use, they refuse to connect to the main router. It says it's on channel 6, with connection of 450MBPS, however this is incorrect as the main router is channel 11, and can not go faster than 144MBPS. Because of this, any build past 29440M 4/19/16 fails to properly conect to the main router. I have to stay stuck on 29440M. What happened with the newer builds that cause the repeater function to break? Is there some sort of fix arround the corner?
*bump*
