Firmware error when upgrading
17 posts / 0 new
extension23
extension23's picture
I just received a new Nighthawk x8 R8500 router. I successfully updated teh stock netgear firmware to the newest netgear firmware, but I am having difficulty upgrading it to ddwrt. I have tried the Kong R8500 chk download file from this site and the R8500 ones from ftp://ftp.dd-wrt.com/betas/2016/11-14-2016-r30880/ but I get the following error no matter which R8500 chk file I try.  I have even done the 30/30/30 before trying the update, but I still get this error.
The firmware is not compatiable with your router. Error code -2.
Any thoughts on what I should try next?
dabirt
dabirt's picture
Same thing here.
Same thing here.
getwwrttoday
getwwrttoday's picture
same here.  Have tried
same here.  Have tried several .chk files and all end in the
error.
Have done resets from the Netgear interface and tried 30/30/30 reset as well.
skeechan99
skeechan99's picture
Seems there is a new revision
Seems there is a new revision/signature.  From the looks of it, it is the Made in Vietnam models that cannot be flashed but the Made in China models can.  Unfortunately my Amazon unit picked up 2 weeks ago is a Vietnam model and I get the same -2 error trying to flash.
jytong
jytong's picture
same here
same here
extension23
I had posted this issue to
I had posted this issue to the dd-wrt forum.  They sugested using a usb ttl adapter and posting the output when flashing to the forum so they could assist fufrther.  Unfortunately the person I was setting this up for didn't want to wait so I no longer have the unit to try and flash and give them the output.  Here is the thread if anyone else having issues wants to get their help roubleshooting.
http://www.dd-wrt.com/phpBB2/viewtopic.php?t=305689&postdays=0&postorder...
Bxmakaveli51
Bxmakaveli51's picture
I get this same error
Any advice or info would be appreciated
nonparity
nonparity's picture
I just tried to flash this
I just tried to flash this and I am getting the same error.
This is a made in Vietnam model too.
sixirouter
sixirouter's picture
Hmm... It seems that Netgear
Hmm... It seems that Netgear UPGRADE the hardware of R8500 to solve the problem of BOOT LOOP...
I got the 3rd R8500... I hope this one can live for a longger time... The BOOT LOOP of R8500 was take me to the hell since I got it first time...
I was already updated it to V1.0.2.86_1.0.75 of the official firmware. Watting for the update of KONG version now.
riedling
riedling's picture
I also have the MADE IN
I also have the MADE IN VIETNAM unit, i purchased at BestBuy, but no kong CHK work on this model ( i tried 4).
Hope an update gets pushed soon, i need my vpn client ;)
rjb0333
rjb0333's picture
same issue here, anyone find
same issue here, anyone find a fix?
junwchina
junwchina's picture
same issue, any solution here
same issue, any solution here?
lck81006
lck81006's picture
same issue...I am come from
same issue...I am come from Hong Kongfrown
sunmachine
sunmachine's picture
Chiming in: Made in Vietnam
Chiming in: Made in Vietnam model here, same problems.
TheBoatswain
TheBoatswain's picture
Could it be they are two
Could it be they are two diffrent routers? one is an R8500, and the other is R8500 Nighthawk X8, just a question.
cdeslong
cdeslong's picture
Need solution also...please
Need solution also...please post new firmware soon!
dracobuild
dracobuild's picture
I successfully updated Vietnam model firmware  to DDWRT using firmware found here:
https://www.myopenrouter.com/download/dd-wrt-kong-mod-netgear-r8500-2017...
This is the first firmware to not get the error code -2 message.
