Hi all. I'm trying to find the board id for the R8500 so that I can convert my Costco r8300 to an 8500 for a kong ddwrt build. I did something similar for a costco r6900 to R7000 and it worked perfectly. I'm looking to install PIA VPN on the router itself. Any help (as in, what is the board id for R8500) would be most appreciated. Thank you.
- R8000P would be grate to see. 1 year 2 hours ago
- Have a R8000 but ordered a 1 year 2 hours ago
Merry Christmas
U12H334T00_NETGEAR
Let me know how it goes, I just purchased the R8300 yesterday and I'm interested.
So I just did some looking, it's funny, both boards have the same board ID
Even more interesting, I just compared the most recent update files for both routers. The files were identical except for the file names
Final update for you, I flashed the R8500 firmware from Netgear to the R8300. The firmware flashed successfully. I believe that this being an R8300 is only by name and the missing USB port.
I will let you try the DDWRT part.
Sounds good. I'll have an update in a week as i am away on business
So, I was able to update using the R8500 firmware, but my router status is still saying r8300. Can you confirm if yours says the same? If the board IDs are the same, the.chk ddwrt firmware should work, but it is not. I'm still getting "The firmware is not compatiable with your router. Error code -2. "
I tried burnboardID with this ID you gave and reset nvram. It still sees it as an 8300. Thoughts?
Sorry for taking so long to get back to you, I no longer have the router. However when I compared the board ids they were the same. There must be something burnt into the chipset telling the router it is something different.
Any update on this, either updating the board or flashing the R8500 ddwrt to the R8300?
I purchased the R8300 from Costco as well and may end up returning it if I can't find a working solution.
Actually? Yes. I was able to flash it to the R8500 by downloading the firmware from Netgear's site. After that, I loaded the ddwrt 8500 build it and flashed successfully. I know have an active "8500" on ddwrt. I highly recommend going for it.
How do flash R8300 to R8500
