I converted to dd-wrt to use a VPN service and now the SSIDs are not showing up for either the 2.4GHz or 5GHz channel. Not even the default versions. Any suggestions?
I should add that it is not broadcasting as hidden either.
I am experiencing the same issue. Have you managed to find a fix?
hopefully you sorted this out, but for anyone else asking the same question the SSID will broadcast as DD-WRT, you will have to rename the SSID's to separate the two, both default to just DD-WRT opposed to the original SSID's being Netgearxx-2.4 & neatgearxx-5
