Cannot access setup after flashing DD-WRT Kong mod
2 posts / 0 new
fbkurtz
 I have flashed my Netgear R6250 router to the DD-WRT Kong mod dated 20170514. The process appeared to complete successfully.
When the flash completed a screen popp​ed up requesting login credentials change, which I did. Now when I http to the url I receive a system information page but when I click on any of the setup or administration links a login box appears and the credentials which I originally entered are refused.
​How can I regain access to the router?
Mastec
That happened to me on both
That happened to me on both of my routers.  Have you tried a factory reset by pressing and holding the rest button for 30 seconds?  When the router comes back up you should be able to set your username and password.
