Hello all,
I have just moved my Netgear R8000 from stock firmware to the latest DD-WRT Kong (dated 5/15/2017) and am uncertian that the 5.0GHZ channels are set correctly for AC to work correctly. Is there anything that I need to do to properly configure the 5.0GHZ channels for AC to work?
Thanks in advance for your replies.
Hmm... i do not know what to advice you
Londonescortsgroup
Yeah select AC... or post what you ave or 'search'. ;)
