Hi everyone. I'ave had my netgear R8000, a while now and I just recently installed DD-wrt on it for the first time. I've used DD-wrt on other routers before, but the stock on my R8000, had everything I needed so I never flashed it. This router has always given me issues where I need to reboot it from time to time, (every couple months).
Anyways, I decided to try dd-wrt. I did a (1)factory reset, (2)reset button on the router, (3) flashed dd-wrt [DD-WRT Kong Mod for NETGEAR R8000 (2017-06-11)], (4) reset button on the router, and finally (5) started setting it up. Setting up = set up wifi, guest wifi, changed the dhcp server to match my old one (192.168.11.x) and set up some static IPs for things I need. Did a couple port forwards and that is it.
It worked at first, but the following day the internet was sooo slow (I did a speedtest I had 1-2mb and I typically get 90-100mb), I couldn't even connect to the router itself. I had to pull the power plug out to reset the router. It worked fine again. Then about a day later the same thing happened. I did a couple more reboots (I was messing with some settings, honestly don't recall which now.) It's a bit better now, but it's dropping packets. I read about it and it recommended changing the wireless channels. That made things worse and packets were dropping like crazy (TX was over 3800). So, I switched it back to auto and rebooted. That was yesterday afternoon and as of now (less than 24 hours later)
wl0
376468 OK, 4 errors
719323 OK, 38 errors
wl1
59188611 OK, 3 errors
29747710 OK, 16 errors
wl2
Wireless Packet Info
0 OK, 3 errors
65826 OK, 12 errors
I'm at a loss as to what to do. Does anyone have any ideas?
Because of the issues, I've been thinking about switching to tomato to see if it works better for me. The question I have there is, can i flash from dd-wrt to tomato? If so, do I still need to do the initial flash, and then the all in one? Do I have to flash back to stock first?
Thanks for taking the time to read this and any help you might have.
Just an update on packet errors. Less than 24 hours after my post I'm up to this many errors.
This doesn't seem right, right?
wl0
895137 OK, 4 errors
1502452 OK, 192 errors
wl1
127672519 OK, 3 errors
61674823 OK, 86 errors
wl2
0 OK, 3 errors
131213 OK, 28 errors
Just so you are aware tomato shibby has poor wifi on certain routers I have an R6400 I have tried dd wrt and tomato dd wrt provides the best wifi the tx errors are normal at this stage as dd wrt is still rather new to the r6400 R8000 etc.
Is teh rebooting daily or every other day common too? Otherwise the network is sooo slow. Sometimes I cannot even connect to the router itself.
Reset to deafult, add and test as you go, properly, you have introduced errors.
